what's in a 120K tune-up?
my car has 112K miles and I've only had it for 1000 miles so I want to give it a tune up. I was wondering what parts should be replaced in a 120K tune up. Parts total cost estimate? Labor? Could i do it myself?
timing belt?
Re: what's in a 120K tune-up?
its the same as 60k tuneup.. im sure but not 100% positive... but you might need water pump, timing belt, timing belt hydraulic tensioner, timing tensioner pulley, and the tensioner pulley tool. If you are familiar with your engine and know what your doing than you can do it yourself ( i did mine myself its a tight space to work with ). http://www.3sxperformance.com/stock.asp they sell the for 91-99 DOHC TT & NA: $379.95 and
91-99 SOHC: $244.95 |
if u replace the timing belt ($180) u might as well do the water pump while ur at it - cause its right there an it isnt really that much fun doin either...you gotta take a handfull of things off the driverside of the engine when doin it- i dont remember what the w-pump costs . but i would get it done.. mine went 287k miles before i had to replace anything - first think i had to replace @ 287k miles was the Thermostat ($45) then the pwater pump gasket went so i replaced that an a new seal($?) then i did the timing belt while i was there - the rest of the car is all orig. i am second owner - bought it from some old dude that looked like if he coughed wrong he would die... he has service records an tune up recipes from 2 months after he bought the car - he had the oil changed every month even if it didnt need it - had the car fully inspected every 2 months buy the dealer that imported it for him .... so i am happy i got it - it was a well taken care of car...an i am only doin the same - just can't afford the monthly oil change - i do it when ever its needed usually over a month though..
the tune up prob. does a check on the injectors for leaks clogs ... an the will prob do a new wire an plug job... shit like that |
Re: Re: what's in a 120K tune-up?
I did all the work myself - an he isnt jokin about the tight space.. u need those trick wrists to get the job done - but if ur a good mechanic an know the engine like he said u shouldnt have a prob... |
Re: Re: Re: what's in a 120K tune-up?
Erik's page is good b/c he has a bunch of pics to let you visualize what you'll need to do. i did the 60k service myself as well. but i was particular and wanted to do it right, so i triple check my timing and everything, thus it took me the better part of 8 hours. also, extra coolant is a good idea as you lose some if/when you remove the water pump. but really, just b/c its a long job doesn't mean its that hard. just have some mechanical know-how, and you're good. also, a friend to help with the timing is nice as you'll need 4 hands to hold the cogs/belt.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Faq
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
its tighter than any other import i have worked on - like for say any honda - vw - nissan maxima an sent.
i opend the hood for alot of people an they all say man that looks complicated - i tell them its really not its just really packed on the top end of the engine... but i found the one bolt on the water pump to be a bit finicky that is the reason i said (trick wrists) figure of speech.... it is a tight engine to work on but i my book its totally worth it - these cars are amazing for how awsome they perform with such small displacement.
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ... ![]() ~FASTER THAN A SPEEDING TICKET~
When I do my 60k, my car is going on a diet, cruise control and a few other things are coming out for good.
how many miles do you have on your car, Geoff?!?! i thought i was near the bottom with just 69k
56k
