Old 02-09-2005, 10:33 PM
nxk2000 nxk2000 is offline
rough then fast idle during cold starts
During a cold start the engine will idle rough. It feels like its missing. If you push on the gas it sputters a little bit then gains rpm slowly. After playing with the throttle a little bit it switches from being rough to a smooth fast idle until it warms up. This only happens during colder days 40deg or lower.
1991 s-10
2.8 v6
tbi injection
no codes
tune up done about 6 months ago
have not checked fuel pressure
Removed iac valve and cleaned
Coolant temp reads normal but is about 7 deg off from 94 s-10 4.3 readings
a nice cone patteren from both injectors
Old 02-09-2005, 11:39 PM
gtmarko gtmarko is offline
Send a message via AIM to gtmarko
Re: rough then fast idle during cold starts
hello i`m having the same problem also but my oil pressure is low and i have to do a pressure test at the sending unit and i have a check engine light on also
Old 02-10-2005, 01:02 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I'd try a bottle of fuel system cleaner. I like SeaFoam, I think it's the best made.
