Old 02-09-2005, 08:49 PM
daustin daustin is offline
99 cavalier 2.4l fuel problem
99 Cavalier Z24 w/2.4l starts up and runs fine, but after shutting it off and leaving it for between 1 and 2 hours, won't start. I crawled under the car to listen for fuel pump to prime, but there is no sound. How do I check if it is a) fuel filter, b fuel regulator, or c) the fuel pump itself?
Old 02-10-2005, 04:45 PM
noshun's Avatar
noshun noshun is offline
Re: 99 cavalier 2.4l fuel problem
Just replace the filter it cheap enough and is part of maintenance. It's to the left of the tank on the inside of the frame rail. The pump you can have tested at autozone and is probably the problem if you can't hear it! You shoudl hear it from the driver seat if you turn the ignit to on and not yet to start. Ig you can't hear it then it's faulty.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
