Old 02-09-2005, 08:39 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
700r4
can anybody remember (specifically) what problems there were with pre-1987 700r4s? I will be buying one and I'm wondering if it will be a problem even though I am rebuilding it and putting a new servos, govenor, clutches, etc. into it.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 02-09-2005, 08:46 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: 700r4
never had a problem with mine and i ragged the hell outa it
Old 02-09-2005, 08:48 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 700r4
by "problem" I think he means the differences between pre-87 and post-87.
Old 02-09-2005, 08:50 PM
Re: 700r4
oh um......?
Old 02-09-2005, 08:53 PM
Re: Re: 700r4
no... don't want to know the differences, I want to know the problems. Apparently GM had significant reliability problems with the 700r4 before they redid it in 1987. The 700r4 used to be a "problematic" transmission.
Old 02-09-2005, 08:58 PM
Re: 700r4
yea see i was right
Old 02-09-2005, 08:59 PM
Re: 700r4
but nah man i dont know the common problems they had... im sure it had something to do with the overdrive maybe
Old 02-09-2005, 09:04 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: 700r4
ha.. What wasnt wrong with them would be a shorter list..
if you have a pre-87 then you need to either get a 10 vane upgrade kit for your pump or just get a 10 vane pump. if you have a 84 or
earlier, get a newer input shaft - they are beefier. also change the front & rear sprags to the new design..
Other than that, a good rebuilt with the right parts and you'l have a solid tranny! Use kevlar clutches, covette servos, Good stuff! it'l make one hell of a tranny that'l hold a lot of power
1991 Camaro Z28
Old 02-09-2005, 09:10 PM
Dober89 Dober89 is offline
Re: 700r4
I can find out exactly what the problem was if you really need it, but basically they had some trouble with the oiling system I think. The newer ones just had an improved oiling pump or something and were more durable.
Old 02-09-2005, 09:47 PM
Re: 700r4
thanks folks.... i'm really gettin tired of this project right about now. I just want to be done with it and listen to my little baby hum as i drive down the highway again. Oh the memories! (tears)
