Go Back   Automotive Forums Car Chat > Fabrication & Tools > Fabrication Tools
Fabrication Tools Discuss and learn about all types of tools used in fabrication, from angle grinders to english wheels.
Old 02-09-2005, 04:48 PM
driver1234 driver1234 is offline
Drill
can I drill through a oil pan bolt with out worrying about sparks
Old 02-09-2005, 06:28 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
If you use a drill bit lubricator you shouldn't have to worry about sparks a bit.
Old 02-09-2005, 07:12 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Drill
Sparks arent really a problem when drilling, especially with lube.
-Mike
Old 02-09-2005, 10:12 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Drill
Oil isnt going to catch on fire even if there were sparks, if thats what your worring about.
Old 02-10-2005, 08:32 AM
RSLaser RSLaser is offline
It shouldnt spark should it? Should just spread shavings?
1991 Plymouth Laser RS
Only sat for a few years....
Old 02-10-2005, 10:30 AM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: Drill
I'm hoping you're not planning on drilling through your oilpan while its still on the motor... way too many metal bits will get in the oil, too risky for me. I did all my oilpan mods while it was off. I'm assuming this is for a turbo drain? You can see what I did in the post entitled "Oil Pan Modifications" or something like that.
