Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-09-2005, 04:36 PM
driver1234 driver1234 is offline
One problem
The oil pan bolt on my Eclipse is stripped. The threads internally are stripped not the head of the bolt. I was not able to get it off no matter what I tried and I used a bunch of techniques. Such as vice grip, pipe wrench, screwdrivers you name it I tried it. All I want to know is:
Is it possible to drill a hole through the oil pan bolt? If yes I assume that there would be no sparks or risk of fire, just metal shavings.
IF NOT
Could I get the Oil out another way like, sticking a tube down the oil dipstick and using suction to get it out?
IF NOT That
I am open to any suggestion but I would just like to know about the drilling.
Old 02-09-2005, 04:52 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: One problem
if the threads internally are stripped then the plug will fall out. explain why you think the threads are stripped? does the plug turn?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-09-2005, 07:24 PM
RSLaser RSLaser is offline
The only reason i could see you might drill it out would be if you broke the head off the bolt...other than that, drilling is a no-no.
1991 Plymouth Laser RS
Only sat for a few years....
