Old 02-09-2005, 04:23 PM
smellywetdog smellywetdog is offline
can i use this fuel injection?
Ok i need help!....I have a 1992 astro all wheel drive astro with a faulty fuel injection ,but I have a 1991 astro as well as a donor van,can these two be swapped?
If so ,is it "open heart surgery" to make the swap?
Old 02-09-2005, 10:57 PM
Kings-x59 Kings-x59 is offline
Re: can i use this fuel injection?
There's a number of guys on this forum that know quite a bit about the fuel injection systems on these vans. A quick search on parts for the fuel injections systems on a '91 and a '92 turns up both a Z motor and a B motor for the '91, both TBI systems. A search on the '92 turns up both TBI and CPI systems. Looks like you might need to post a bit more background information on what you have.
Old 02-11-2005, 03:51 PM
Re: Re: can i use this fuel injection?
yes indeed king-x59,i can supply you all with some additional info....its a "w" engine,central multiport fuel injection,and the donor van is a throttle body type system.I did plan to swap the whole system from 1 to the other,but only if you think it can be done with minimal headaches.
Old 02-11-2005, 03:57 PM
Re: Re: Re: can i use this fuel injection?
oh i forgot to ask if the fuel pressure regulator(the part the mechanic said was no good,can be taken apart seperatly and a new one replace it or do i have to replace the whole shamoozle fuel injection unit like he said!
Old 02-11-2005, 07:44 PM
Looks like your mechanic is right.
Old 02-11-2005, 08:36 PM
..........I was afraid you'd say that!..hehe...I hope he's gentle!...this is gonna hurt
Old 02-12-2005, 05:36 AM
CD Smalley CD Smalley is offline
No, the FP regulator can be taken apart quite simply on a TBI unit. I've done it dozens of times. There are rebuild kits available from Borg Warner that include all the gaskets and the diaphrahm for the regulator. Everything but the spring. Surely one of your units has an intake spring...
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-07-2005, 04:26 PM
thanks cd smalley,im sorry i havent been online to respond with a thank you earlier,but been crazy busy.ill look into pulling the fuel injection apart and getting my hands on the fuel pressure regulator,and hopefully i can rebuild it.could you suggest a site to get a price online,as i live in canada and the pickins are pretty slim around here!
