Old 02-09-2005, 03:56 PM
paulfischer paulfischer is offline
Electrical whine???
Noticed the other day that I hear a whine coming from front of car. (Alternator side) Dont really hear it at idle, but when you accelerate, you can hear. Kinda faint, like a motor winding. If that makes any sense. You can hear it change its pitch as you give it gas or let up on the gas.
Will be checking wires, to see they are close to the alternator, or damaged. Any other thoughts??
The alternator was replaced about a year ago.
Thanks
Old 02-09-2005, 05:55 PM
MarkNYC MarkNYC is offline
I had a similar problem and brought it to dealer for service. AFter two tries, they finally fixed the whine, which turned out to be the idler pulley. Not a big deal to repair.
Old 02-09-2005, 05:58 PM
I'm actually going to be replacing the belt and pulley tomarrow. So we shall see!!!!
Old 02-09-2005, 07:12 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Electrical whine???
Alternator howl or whine is real common on these. Mines been doing it for years. Sometimes it is a prelude to failure, sometimes not. See if it increases in intensity when you turn on the lights and the rear defrost. If so, that's what you hear. The sound intensifies with load on the alt.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-10-2005, 09:18 AM
It comes and goes, definetly not constant. I'm sure its prob the alternator.
Just wanted to get a some other ideas as to what it might be.
Paul
Old 02-13-2005, 02:43 PM
Put a broomstick on the alternator while it's running and listen to the other end up to your ear. If it's the alt, it will be real obvious by doing this.
...empty gun rack.
Old 02-13-2005, 04:05 PM
cadgear's Avatar
cadgear cadgear is offline
My PS pump does a kind of whine when cold off and on for about a minute, then goes away. Doesn't sound like a bearing, but its something to think about.
Old 02-13-2005, 06:58 PM
gwjturner gwjturner is offline
I also had this issue on our 91 3.1L. It turned out to be the water pump. I would definitly check both the idler and the water pump.
Old 02-13-2005, 07:16 PM
Corndog Man Corndog Man is offline
Re: Re: Electrical whine???
My '99 did the same thing for about six months. The alterator finally died and was replaced. No more whine. It could be anything on that side though. Mine was almost a whistle sound.
Old 02-13-2005, 10:01 PM
the water pump was replaced about 2 yrs ago.
and the alternator was done a year ago.
I'm changing the belt and idler pulley tomarrow.
I'm leaning toward the alternator.. will do the broom test tomarrow as well.
Old 02-13-2005, 11:00 PM
Spin the alt pulley when you have the belt off. Should feel smooth and "damped" somewhat. If it feels dry or gravely, that could be it. Spin 'em all while you're at it. Maybe start it for a minute with the belt off, make sure it isn't something else.
...empty gun rack.
Old 02-14-2005, 07:28 PM
cadgear's Avatar
Aye, start the car with the belt off for a moment or two. If you think about it, all the accessories use bearings which can fail and the same belt drives all of them. Probe around a bit with a broomhandle or a long screwdriver to your ear.
