Old 02-09-2005, 03:23 PM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
Unhappy Help RST!!...
Ok remember how i said my car runs now... well it runs now, but the oil isn't pumping into my heads. Do you know what can cause this? The oil pump is working and the car starts now, but there is no oil going into my head. Do you think its clogged up somewhere? I have 60psi for my oil pressure. =\
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 02-09-2005, 06:49 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Help RST!!...
I have no real idea...especially since we have no info about your car...
Put your car make/model/year with tranny and any mods into your sig.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-09-2005, 08:37 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: Help RST!!...
what did you do to your car that might have caused this?
Old 02-09-2005, 08:46 PM
Re: Help RST!!...
ok i have a 96 RS stock. ok i think i might of found the problem... my head is fcuked up and causing it not to get any oil into them. Its been like ever scince August 04" i been working on it... and we finally figured out what was wrong with my car just on Monday of Feb 05". =\ My lifters are making a loud knocking sound and i guess my heads isnt getting any motor oil thats what my dad said. so thats the case there. Ill check back to see if i need help =\ thanks
Old 02-09-2005, 09:23 PM
GotGrip666's Avatar
Banned
Re: Help RST!!...
have you messed with the oil pan at all?
Old 02-09-2005, 09:33 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
Re: Help RST!!...
Is it possible the head gasket is blocking the path?
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 02-09-2005, 10:12 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Help RST!!...
If you have the headgasket on upside down/backwards that would definately be the case! Other than that if your getting 60psi of oil pressure your pump is obviously working correctly.
Old 02-11-2005, 01:11 AM
Re: Help RST!!...
ok it was the head that is messed up man. The dang head broke my cam key and everything... but yeah it might be the gasket that is blocking the oil.. but who knows. All i know is that im getting a brand new head w/ all new lifters, cames, etc.. =) i hope i get it done so i can have it ready for summer.
by the way.. can a 96RS equipped with AEM vs intake, 60mm throttle, headers + 2.25 piping with exhaust be fast enough to smoke some hondas? like vtec? or just get make a turbo kit?
Old 02-11-2005, 06:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Help RST!!...
What could possibly be "messed up" about a head that limits oil flow to the cams? Its chunk of aluminum, not sure what could go wrong there. The gasket things seems much more likely, but only if you had changed it when the problem started, in which case, I would hope you would have suspected the HG swap right away. I could see one passage blocking up, but not all of them.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-11-2005, 01:54 PM
Re: Help RST!!...
man i don't even know what caused it to do that. but i know that the first oil pump wasn't even working =\ but i think it might of clogged up or something.. it wore out where the cam shaft meets the cam gears. I was all scatched up and also broke my cam key. But now i know that im getting a brand SPANKING NEW head w/ everything. =)
