Old 02-09-2005, 02:38 PM
Hitman5645 Hitman5645 is offline
pathfinder lift kit
I have a 1996 pathfinder and I just got these hot tires, 35x12 16, I tried putting them on but their too damn big, haha I knew they werent gona fit, I lucked out with these tires at a junkyard, got them for 300 dollers they still have the little pins on them, theirs prtolly like 300 miles on these tires, anyway, I cant find a lifkit for my pathfinder, can anyone help me out here. sites, numbers to call, anything. I just cant find anything for it. I want a suspention lift more then just the body, but what ever is there to make it higher I WANT IT.
Old 02-12-2005, 03:32 PM
mike5721947 mike5721947 is offline
Send a message via AIM to mike5721947 Send a message via MSN to mike5721947
Re: pathfinder lift kit
i have also looked at a lift lit for a pathfinder and havent found any but you might want to try looking at other nissans that have the same suspension (one of there trucks has the same suspension i think)
http://www.jcwhitney.com/autoparts/P...odelId-1001572
Item#: SL90
SUPERLIFT 1.5-2.5" PKG. 86.5-97 NISSAN HARDBODY P/U 4WD $411.00
fabtech as far as i know only makes lifts for the nissan pathfinder up to 92
Old 02-12-2005, 09:08 PM
mospeed1 mospeed1 is offline
Send a message via AIM to mospeed1
http://www.4x4parts.com/public_html/...b48f3997ed2424
4x4parts.com all the sell are nissan parts check them out
02 rodeo ls
old ride 95 200sx full showcar
Old 02-12-2005, 10:28 PM
ya but its only a 2 inch lift and only will fit 31" he is trying to fit 35x12" looks like you need to get a suspenion lift and a body lift and fender flares. and that might just let the tires fit
Old 02-12-2005, 10:36 PM
Andydg Andydg is offline
You're also going to need lower gears to turn tires that big with that small of an engine.
Old 02-19-2005, 01:14 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I don't think the differentials on those can handle tires that big, even with a re-gear. If I remember right, 32" is as big as you can go with the stock diff. without causing major damage later on.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-21-2005, 11:25 PM
J-Ri's Avatar
Found the book, max tire size is...
Nissan
Front IFS (early) 30"
Front IFS (late) 31"
Rear 27 spline 31"
Rear 31 spline 33"
Old 02-26-2005, 04:07 PM
jtrollop jtrollop is offline
http://www.4x4parts.com/public_html/...e6ab29af78c3ad
This site has a 2" lift for a 96' pathfinder.
