Oil Leak......... Valve cover gasket or Head Gasket??
well i recently had my timing belt done. its been col hear latly and i store my car for the summer. so latly ive seen oil on the ground and see oil on the block. is it because the valve cover has mabey loosed a bit or possiablility that its coming from a leak in the head gasket. i always look for leaks on my car, and never seen any oil leaks before. what do you think you gurus out there thanks jono
It Should Be Your Valve Cover Gasket. The Headgasket Goes And Antifreeze In Your Oil Is The Symptom. Plus White Smoke Out The Exhaust. If It Just An Oil Leak It Should Just Be Your Vavle Cover Gasket. Did You Replace Your Oil Seal Swhen You Rtiming Belt Was Done.
Re: Oil Leak......... Valve cover or Gasket??
Yeah, you should also prolly check your main oil seal. That went bad on mine and lets just say I had to refinish my garage floor...
Re: Re: Oil Leak......... Valve cover or Gasket??
thanks but i had it done at the Honda dealership and i know the guys real good so i would trust that they did it all.
