Old 02-09-2005, 11:49 AM
Gomer4ever2005 Gomer4ever2005 is offline
70,000 miles do i need my transmission fluid Changed?
I just got my 98 grand prix it has 70,000 miles on it i dont know if the tranny fluid has been changed can anyone tell me if i should get it changed before i put on 3.4 pully?
Old 02-09-2005, 12:17 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: 70,000 miles do i need my transmission fluid Changed?
Yes change the fluid and filter....dont not have a power flush done,unless you plan on replacing the tranny.
ClubGP Member 6530
Since 2001
Old 02-09-2005, 08:43 PM
pommer2005 pommer2005 is offline
Re: Re: 70,000 miles do i need my transmission fluid Changed?
Hey BIG-L, why should you not have a power flush done? I've heard of people saying not to do it but I do not know the reason not too.
thanks
-josh
Old 02-09-2005, 09:02 PM
BIG-L's Avatar
It can break sediment lose from inside the tranny,like clutch dust and other foreign materials and push it into places it's not wanted
~Larry~
ClubGP Member 6530
Since 2001
Old 02-10-2005, 07:31 PM
jon95se jon95se is offline
http://www.automotiveforums.com/vbul...d.php?t=362456
read my post there, and make your own decisions
thanks
Old 02-11-2005, 11:44 PM
onstar onstar is offline
what exactly is a transmission flush? same as oil change. and why do some think its bad?
Old 02-13-2005, 08:15 PM
if i were you, i would have it done, others hear believe that there is more harm done then good. seeing how i have performed this service hundreds of times, and only had one bad tranny out of the deal in 8 years. i believe it to be good. they hook the machine up to a cooler line. and as your car idles, your transmisson slowly pushes the old fluid out of the transmission. as the old fluid comes into the machine it pushes the new fluid into the transmission. it completely operates off of the pressure of your transmission. if your "filter" is bad, the machine will not be able to do its job, as your transmission will not have adequate pressure. in effect. the machine that I use holds 18qts of oil. your transmission only holds 12 qts max. in effect it exchanges your fluid by dolution of the old.
i do it every 30k. and on my new beeter. it was the first time it was done.
