Old 02-09-2005, 11:20 AM
UDGRAD UDGRAD is offline
Unhappy fast blinking signal
I have a 98 4dr blazer. my left turn signal blinks fast. the right one is fine and the flashers are fine. I have checked the fuses and they're fine. I changed the signal fuse under the glove compartment. None of this has worked. any other suggestions?
Old 02-09-2005, 11:57 AM
Alexxn 00 Si Alexxn 00 Si is offline
Re: fast blinking signal
It usually means that you have a burned out bulb on the side that is blinking fast......
2005 Chevrolet Silverado 2500HD Ext cab
Old 02-09-2005, 11:58 AM
anthony464 anthony464 is offline
One of the bulbs may be bad, check for rust in the socket, add grease if needed.
Old 02-09-2005, 12:43 PM
thanks i'll see if this works
