Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-09-2005, 12:18 PM
phideltkuntryboy phideltkuntryboy is offline
Send a message via AIM to phideltkuntryboy
Secondary Air Injection System Malfunction (code P-0410) PLEASE HELP
Howdy,
I have a 2001 s-10 2wd. Recently my service engine light came on. I went to auto zone to have them check my data port. It said there was a 2ndary air injection system malfunction. The code was p-0410. It said there 2 problems with the injection system. What does this do? How can I fix this myself? Thanks for your help.
Old 02-09-2005, 12:42 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Secondary Air Injection System Malfunction (code P-0410) PLEASE HELP
Read this thread it should help:
http://www.automotiveforums.com/vbu...ad.php?t=359793
Old 02-10-2005, 10:11 AM
Blazee,
Thanks for that referrel. it hits the problem right on the nose will check it out and see if i can fix it, thanks again.
Old 02-10-2005, 10:41 AM
blazee's Avatar
Problem?
You're welcome, good luck.
Old 01-13-2008, 09:42 PM
fly066 fly066 is offline
i just had the same code , pump had water in it was drained,code reset and both fuses are ok . drove 24 miles light came back on. Smells like motor is burnt. I live in new york you think the water froze up hurting the motor? Is this a common thing or is there another solution to fix this ? Pump did run when hooked up to a battery to check it . Thanks
Old 01-14-2008, 11:10 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
this thread is almost 3 years old. please refrain from posting in old threads. feel free to make a new thread in the problem diagnosis section.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
