Old 02-09-2005, 10:50 AM
Williomi Williomi is offline
Send a message via ICQ to Williomi Send a message via AIM to Williomi Send a message via Yahoo to Williomi
engine throwing bad fuel injector code
engine light blinking 17 times is there any way to check fuel injectors?
thanks for ur help
Old 02-09-2005, 10:55 AM
big bad mohawk guy's Avatar
big bad mohawk guy big bad mohawk guy is offline
Re: engine throwing bad fuel injector code
some times the little wires on top of the injectors can be lose and through a your light.but you can pull them out and put them in part cleaner
1988 crx hf
cool air intake
#1 racing exhaust
sprint spings
B&M SHORT SHIFTER
gutted cat.
Old 02-09-2005, 12:58 PM
Dastreetracer's Avatar
Dastreetracer Dastreetracer is offline
17 is not fuel injector code its vss code 16 is fuel injectors.
Old 02-09-2005, 01:03 PM
DJHyperXK2004's Avatar
DJHyperXK2004 DJHyperXK2004 is offline
Send a message via AIM to DJHyperXK2004
Re: Re: engine throwing bad fuel injector code
i get the same code on my dpfi, but never did anythng about it, maybe ii'll try this, on the weekend!
1990 DX Hatch
17" 5Zigen Copse Rims
CIA, 4-2-1 Header
H/F Cat, 5Zigen Exhaust
Circle Earth kit
B swap in the spring???
PIX OF MY CAR
Old 02-09-2005, 04:01 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
same code in my dx, never had a problem though... do you have a 16 bad injector or 17 vss?
Old 02-10-2005, 12:28 PM
Well all the harnesses looked pluged in nothing loose around the tranny but a single wire is no longer connect into the harness must be the problem any way to fix this or does it need a new harness?
Old 02-10-2005, 12:33 PM
do you know how to solder?
