Old 02-09-2005, 10:32 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Injector Question
Hey Guys!!
Quick Question...
What is the difference between the all the different injectors for the dsm? Like there are the "stock" ones, blue top, yellow top. Just wondering. I know that they yellows are 510cc, but basically what is the difference in the blue and non-blue. Are there any other stock dsm/jdm injectors as well??
Thanks for the help!
Alex
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-09-2005, 10:58 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Injector Question
Originally Posted by bighauns
Hey Guys!!
Quick Question...
Alex
I am interested in this also. I have been seeing that some people are using the 560cc EVO VIII injectors. Is it that any low impedence injectors will work? Anyone know of other cars we can "swipe" the injectors from, so I don't have to pay $300 for a set of 550's?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-09-2005, 07:32 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
you can use any low inpedence,peak hold injector.i dont really know about the evoviii but the rx7 turbo2 from 86-88 will work,some are low imped but some are not.they are a red top denso 550 injector in the rx7.
i could do some searching and really find out about the evoviii though.
Grab your multimeter put it on OHM's and touch the two prongs and check the reading. If its 2-4 Ohm's then it's the right stuff.. If it's 10-15 ohm then sell them to your Honda buddies..
they have a red top
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
