Old 02-09-2005, 08:29 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Squealing Belts!!!
Ok, heres the deal, I put new belts on about 4 days ago for my crankshaft pulley....AC and Alternator I believe....I was wiring my gauges yesterday and i started my car....I think the host rubbed against one and now they squeal after the car warms up. I was working on the car with my hood up for a few hours but this morning it did it again. Anyone have any ideas why my belts are doing this besides the hose and how can I fix it?
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 02-09-2005, 09:13 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Squealing Belts!!!
Are you sure that you have the belts tightened enough? You could use some belt dressing, but I have never had good luck with that stuff.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-09-2005, 01:17 PM
positive i tightened them enough, i was with my mechanic/massage therapist
95 Eclipse GS-T
Currently:
Soon lol
Old 02-09-2005, 01:24 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
maybe you overtightened them. for tightness on my belts i like to be able to grab them between the crank and ac compressor and be able to turn it a little over 90 degrees. that usually works very well for me.
95 Talon TSI AWD
97 Eclipse GST
Old 02-09-2005, 01:52 PM
I made sure i check by checking a different belt tightness and did the same to the 2 i put in, is this a likely problem though for it to happen like 3 days later??
95 Eclipse GS-T
Currently:
Soon lol
Old 02-09-2005, 02:03 PM
Martanya95 Martanya95 is offline
Hey besides checking your belts tension check the bolts that hold the alternator and power steering pump on. my used (by someone who didnt care) 95 when i got it was missing a bolt on each which caused it to make a horrible squeal and tear apart belts or just throw them off.
Old 02-09-2005, 08:42 PM
Those are tightened also, after the car warms up its fine but when i pop the hood after their squealing it smells like burnt rubber....not strong but i can smell it a little bit
95 Eclipse GS-T
Currently:
Soon lol
Old 02-10-2005, 08:25 AM
does anyone think it would have to do with something maybe touching the belts while the car was running??
95 Eclipse GS-T
Currently:
Soon lol
Old 02-10-2005, 09:41 AM
oxygen800r's Avatar
oxygen800r oxygen800r is offline
what type of belts did you put on?
i had gatorbacks on mine when i did the timing and it squealed like a bitch. it wasn't the tension either because i adjusted it a million times. i changed the belts to oem and it stopped squealing right after.
Old 02-10-2005, 11:22 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I also have a problem with squealing belts. Not really much you can do, as I have found out. Don't use belt dressing, it makes it worse. Just keep trying to get the right tightness, experiment a little. Mostly happened right after it rained or there was a lot of moisture in the air. Shouldn't hurt the belt, as far as I know. Let me know if you find something that works good.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
