Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 02-09-2005, 07:59 AM
drifters drifters is offline
Thermostat Reading Wrong
Hi,
I was wondering what could be causing the temp gauge to fluctuate? I mean it would go to the middle where it is suppose to then it would go back down to 'C'. When I start driving it will start slowly dropping an d when I idle it would rise. What could be the cause of this? Please let me know. Thanks.
Old 02-09-2005, 04:31 PM
Talibangunner925's Avatar
Talibangunner925 Talibangunner925 is offline
yea i got the same problem. On the ecu read out it was sendign a code sayign that there was a tempatre surcuit poblem and then i found out it is eather the water temp sensor which is a easy fix and cheap or the thermostat which means u have to rip off the whole front end. How ever i would just change the water temp sensor and see what happens. not only that if it goes up and down it is mroe than likely the water temp sensor
Old 03-15-2005, 08:00 PM
gavric's Avatar
gavric gavric is offline
Re: Thermostat Reading Wrong
Anyone has any clue where is this water temperature sensor? Thanks
Old 03-15-2005, 08:46 PM
http://www.audiworld.com/tech/eng.html
Old 08-30-2005, 03:54 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
it is behind the engine in the dead center it has a 4 wire harnes that goes to it. just take it out and clean it with a wire brush and clean the connectors and sensor with carb cleaner and it will fix the problem. it has for me with many cars. good luck!
Old 08-31-2005, 07:46 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
The old style ECT is black, the new updated one that helps prevent corrosion is green. There a pain to replace because of the space you have between the sensor and the firewall. Very common problem with these to fail.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-01-2005, 01:14 PM
it was verry easy to replace for me took me about 2 min
