Old 02-09-2005, 06:59 AM
Elijah04 Elijah04 is offline
Question Kit problems
What kits give you problems the most
Old 02-09-2005, 07:27 AM
Junhao's Avatar
Junhao Junhao is offline
Send a message via ICQ to Junhao Send a message via MSN to Junhao
Re: Kit problems
Tamiya 1/20 BMW Williams FW24
Home of the Supercars:
Old 02-09-2005, 07:39 AM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
Re: Kit problems
The ones I'm building.
Old 02-09-2005, 04:04 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Why? I'm going to be starting one in the not too distant future, what problems have you encountered? - Mark
Old 02-09-2005, 04:36 PM
Vric's Avatar
Vric Vric is offline
Re: Re: Kit problems
Same for me.. The rear crawl simply don't fit on mine
Old 02-09-2005, 05:14 PM
Amazon's Avatar
Amazon Amazon is offline
Re: Kit problems
What kits give me problem? The ones that doesn`t cooperate during the building process! They tend to loose parts( I had it 5 minutes ago!..) or the ones were the body has paint-allergy( paintjob screws up ..) and so on..
In short, every kit/buildup has some problems on the way from the opened box to the displaycase
Newsflash: Diecast sales fund terror activities.
Old 02-09-2005, 05:17 PM
blubaja's Avatar
blubaja blubaja is offline
Re: Kit problems
Hey,
Um...can't remember specificly, but fiddly front suspentions are a bitch. Getting glass to stay put w.o falling out or smearing it up wiht glue or paint.
Frank X.
Old 02-09-2005, 08:15 PM
Junhao's Avatar
Re: Kit problems
-Rear cowl doesn't fit
-Monocoque is divided into two parts, which means u have to paint the seat, glue it in place then paint the exterior with the seat masked. Makes painting a hell of a job.
-2 tone paint scheme, masking of body is quite hard with irregular pattern.
-Fragile decals
Maybe it's just I'm not good enough to build the kit but I've built the Ferrari F2001 and it's just fine.
Old 02-10-2005, 09:43 AM
Thanks for the heads up on the Williams. I built the Ferrari F2001 too and thought it was a beautiful kit, the Williams kit parts look impressive too. Since I'll be doing the Williams for an article I guess I'll pass on any work arounds I find... - Mark
Old 02-10-2005, 09:51 AM
Vric's Avatar
-Fragile decals
well beside the 2 tone paint problem (I found it easy since they give decal to go over the joint line) I got the same problems as you.
Old 02-10-2005, 09:31 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: Kit problems
Oh, c'mon. Tamiya kits are works of art compared to some poorly done resin kits.
I have TKM's Lincoln Mk.VIII, and well...it's like this:
http://www.asahi-net.or.jp/~xr2h-fkd...viii/mk800.htm
It's faster to scratchbuild it instead of fixing this model.
Hiroaki Fukuda
Old 02-10-2005, 09:35 PM
tonioseven's Avatar
Re: Kit problems
Geez, it looks to have come from the behind of a very sick man!!
Old 02-10-2005, 10:52 PM
RallyRaider's Avatar
Zomby Woof
Re: Kit problems
Yikes, that TKM Lincoln will take some beating on the worst possible kit list. Fashioning a model with a rock and chisel would require less work!
Old 02-10-2005, 10:57 PM
Technoman's Avatar
Technoman Technoman is offline
Oh my, that is absurdly crude...
Old 02-11-2005, 03:40 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Re: Kit problems
I think that's the worst kit I've ever seen!!!
I'd like to see one of the top modellers on this forum have a go at it and see if they can make something which resembles a car!!
