Old 02-09-2005, 06:39 AM
frank906 frank906 is offline
Headlights don't work?
'98 FB, low beam headlights don't work. High beams do work? Checked for fuses? ,any thoughts? Could both be burned out?
Old 02-09-2005, 08:47 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Headlights don't work?
Welcome to the forum Frank and sounds like a relay or switch issue to me.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-09-2005, 01:53 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
I had that problem with one of my headlights a while back when I first got my car. Turned out that the low beam filament was burned out, but the high beam filament was still in tact. So whenever I would turn my headlights on, the low beam wouldnt work, but the high beams would. All you have to do is go up to a nearby AutoZone or Advance Discount Auto Parts and buy some new bulbs. I think 2 of them cost me about $40 together.. It's not too expensive. Maybe someone here else knows where you can get cheaper lights. But I'm pretty sure that's your problem right there.
Old 02-09-2005, 02:08 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
yeah ur bulbs are blown most likely, it happens, replace one, if it works, then buy the other (no point in wasting cash)
Old 02-09-2005, 02:36 PM
pontiacpmpn's Avatar
pontiacpmpn pontiacpmpn is offline
Send a message via AIM to pontiacpmpn Send a message via MSN to pontiacpmpn Send a message via Yahoo to pontiacpmpn
Re: Re: Headlights don't work?
I'd Think that it would be a relay or somethin like formula said, its kinda odd for both bulbs to go out at the exact same time... But you can check that without buying new ones, just pull the bulb out and look at the filament... if there is a spring lookin wire connected to the wires on both sides of the bulb, then they are good, if it's damaged or missing.. buy new bulbs. That should save you even more money if it isnt the bulbs...
|1979 Firebird Formula W/T-Tops | 1997 Saturn SC1 | 2001 Harley Davidson Sportster 883 |
Old 02-09-2005, 04:13 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
i was thinking the hi beam low beam switch but....
Old 02-09-2005, 10:38 PM
Well it turns out both low beams were burned out!!, at the same time...pretty weird huh!
Old 02-10-2005, 03:38 AM
That is odd... I guess it happens though, on the plus side, you can replace them with some of them super bright xenon bulbs
