| N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
Need Turbo Advice
I have a 97 civic with a stock GSR engine in it. I want to put a low boost turbo on my car. I just picked up a drag manifold and a garret turbo (T3 i believe). I am wondering if I can get away with just using a FMU as long as I keep the boost low? Or do I need to modify other parts of my car to acheive this? Also what honda fuel parts can I leave stock if my goal is to have 220hp daily driver.
Re: Need Turbo Advice
its going to be as reliable as you make it. i personaly dont like fmu's but i have seen them used up to 7 psi. the better tunned you are the less chance of blowing it and thers not much tunning to an fmu. i went with a safc, walbro 255 pump and 450cc injectors and its worked fine for me. this way you dont have to mess with the map sensor or your fuel pressure. i run 10 psi daily with this setup.
colder plugs , intercooler and retarding your timming will also decreese the chance of detnating fuel is the one thing you dont want to be short on |
I wouldn't skimp on the fuel management system. I would put in an Uberdata or Hondata system on that set up just to prevent future problems w/ detonation. I would also for sure buy new injectors.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
you can do the fmu, but, that is so old school. there are so any new and better fuel management systems out nowadays.
when the day comes for you switching from the FMU to a better fuel management system, you will wish you had got it in the first place. i also think you can do better than the drag manifold. try blox or inlinepro.
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
i heard that the tubular mani's are kinda crappy tho?? Is that true? I don't have any experience w/ them , but i have heard that the welds break and they start to leak.
tubulars are more prone to cracking compared to cast, but, theres positive and negative aspects of both.
blox and inlinepro cast iron is a nice manifold with a good position for the wastegate compared to drags. i like cast because it just gives you more room to work with, but, if you want more on the performance side, tubular manis are the way to go.
