Old 02-09-2005, 01:57 AM
Officer Redneck's Avatar
Officer Redneck Officer Redneck is offline
Send a message via MSN to Officer Redneck
Engine stuttering
I have a 1997 Blazer LT w/ engine code w. My problem is when I have my defroster on, the truck seems to stutter a-lot. As soon as I shut off the defroster it clears up. Now, i'm pretty sure that's not normal but my last vehicle (a Ford Explorer w/ 190,000 miles) did the same thing. How do I fix this or is thois something I just have to live mith. Thanx in advance, Redneck
2003 Honda Element EX
2002 Kia Spectra (can't "Improve" or wife will kill me)
1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot)
" Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White"
http://www.myspace.com/officer_redneck
Old 02-09-2005, 02:05 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Engine stuttering
Defroster uses the AC compressor to dehumidify the air.
Are you using the fan full blast while doing this too?
If so, don't do that.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-09-2005, 02:08 AM
Re: Re: Engine stuttering
No, it does it with the fan on low or high. It doesn't seem to matter what setting it is on. Could it be low on freon?
Old 02-09-2005, 05:07 AM
ricksza's Avatar
ricksza ricksza is offline
With the engine running and the defrost on, check under the hood. Is the compressor engaging on and off quickly? If so, the freon charge is low.
Old 02-09-2005, 01:56 PM
BlazerLT's Avatar
AF -Advisor
It could be that or the compressor bearings are gone and the engine is struggling to rotate the compressor.
Old 02-09-2005, 02:04 PM
ricksza's Avatar
Usually the belt gets smoked up at that point.
Old 02-09-2005, 02:30 PM
BlazerLT's Avatar
AF -Advisor
Not always.
The compressor bearings might not be completely shot and the belt is probably a good one that is not allowing the slip.
Old 02-12-2005, 01:24 AM
Not always.
Yea, the compressor goes on and off anyware from 27-35 times in a two minute period. There is a slight whine from something on the engine but I can't pin-point it.
Old 02-12-2005, 01:36 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Engine stuttering
Ok, do this for me, disconnect the electrical connector from the top of the compressor and leave it unattached until you fill your A/C system again.
The compressor going on and off like that is a sign of low refrigerant.
Remove the electrical connection or BYE BYE AC system.
I am not joking, DO IT
Old 02-12-2005, 01:45 AM
Re: Re: Re: Re: Engine stuttering
No problem. I'll fill it tomorrow. Should I put the combo sealer/oil/freon in it or just a freon/oil charge can?
Old 02-12-2005, 02:46 AM
BlazerLT's Avatar
AF -Advisor
freon/oil only unless you expect a leak which I doubt.
You sure you know how to do it properly?
Old 02-12-2005, 08:29 AM
Yea, I did several on my Explorer. The kits are pretty self-explanatory. Thanks for the input
Old 02-12-2005, 12:42 PM
BlazerLT's Avatar
AF -Advisor
With the freon and oil topped up, the compressor cycling should stop.
Old 02-22-2005, 07:10 PM
Sorry it took so long to get back, my mother-in-law had a heartattack. I filled the ac up and it quit cycling so much. I still have the stuttering prob. Tune-up done 3 weeks ago. Any more input?
Old 02-22-2005, 07:52 PM
BlazerLT's Avatar
AF -Advisor
What did the tuneup include.
