Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 02-08-2005, 10:16 PM
armagh armagh is offline
DRIVERS HEATED SEAT IN 2001 Silhouette
MY 2001 Silhouette THE DRIVERS SEAT HEATER DOES NOT SEEM TO WORK IS IT THE ELEMENT OR MAYBE A FUSE, PASSENGERS WORKS
Old 02-09-2005, 09:14 AM
gls02 gls02 is offline
Seat
My 2 year ago my heater element was replaced in the drivers seat. 3 months ago the same seat didn't work again, so I moved the seat up and down, seat back forward and back to the origional position and the seat started working again. I checked for a loose connection under the seat but couldn't find one. Yours might be the heater element, but try moving the seat around first.
Old 01-02-2006, 03:42 PM
troyandmarsha troyandmarsha is offline
Re: Seat
just a note for the searching record:
i've replaced 2 heating elements on the driver's side, passenger side
original still works.
the right relationship is everything,
troy
Old 01-02-2006, 03:56 PM
scannr89 scannr89 is offline
Re: DRIVERS HEATED SEAT IN 2001 Silhouette
if you pull the seat cover off( not fun) you will find where the wires shorted,,this can be repaired
Old 01-13-2006, 04:47 PM
testing99 testing99 is offline
Re: Re: DRIVERS HEATED SEAT IN 2001 Silhouette
Do you mean broken wire or wires ? or
Shorted either to ground or another wire ?(usually fuse will blow)
Can be repaired hmn i assumed that the element would be toast but if it's just a broken wire it should be fixable. Can you describe were the problem occurs.
thks. Peter
