Old 02-08-2005, 09:38 PM
Gsir8 Gsir8 is offline
Send a message via AIM to Gsir8
Question about floor pans
I need to replace the floor pans in my 72 El Camino, and I see that for the Chevelle they sell the front half and rear half, or full length. Do el caminos have different floors than the chevelle, or do they have the full lenght floors from the chevelle?
Old 02-15-2005, 07:43 PM
acewelderman's Avatar
acewelderman acewelderman is offline
Re: Question about floor pans
Im not positive but I think if the years match the floor should be close to the same .Still better ck for sure!!!I just know how to put it all together.Are you planning on doing the job yourself?Ive been thinking & behind the seat must be dif than chevelle .
JUST WELD IT !!
Old 03-14-2005, 10:02 PM
chevyboyy chevyboyy is offline
el caminos have exactly the same everything as the chevelle but are like wagons wit the 2nd set of seats,floors and doors removed and no cover for the bed so if you were to order just the front half of the floor section from any repro comp like npd year one etc that should be all you need unless you intend on replacing the bed to
Old 09-03-2005, 04:34 PM
blue4X4 blue4X4 is offline
They may look simular, but may have slight differences. I would call the parts supplier to make sure, or get a chevelle restoration catalog for the correct pans. Slight differences may mean a tougher time getting them to fit and could end up hacking them up to make them work. Someone out there sells them.
Check out my 1966 Chevelle here:
http://hometown.aol.com/abrucelee1/i...ml1badrat.html
