High reving all the time
Well i havent had to much trouble for my blazer in the year i have owned it but now it is just a bit annoying when I start up and it is sitting at about 2000 rpm, and when i take off it still wants to pass people doing the speed limit? what the heck is happening
Re: High reving all the time
Vacuum leak?
1995 Factory Blazer Service Manual for sale, PM if interested. |
how high is it reving when you are driving?
2001 GMC Jimmy SLS 2-door Manual Trans 2wd 120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla2007 Ford F150 supercab lariat 2wd |
Sounds like a bad temp sensor, if you have a scanner you can view the reading. If the engine is hot and its still reading cold the engine will run at 2,000 RPM. They are only a few bucks if you just want to try and replace it to see if that does the trick.
temp sensor will not increase the idle to 2000rpms though.
Only an IAC or a major vacuum leak will.
Re: Re: High reving all the time
Scrub them both good with TB cleaner and a toothbrush. Then reset your computer.
okay thanks Lt
