Old 02-08-2005, 07:37 PM
spasticone spasticone is offline
code 54.....Stalling Blazer
Ok 94 Blazer 4.3 auto.
A few months ago I had a stalling/hard start problem on 4 occasions. It threw Fuel pump/fuel delivery codes so a new fuel pump went in. Now 3 months later it stalled while idling. It started right up. I drove home and it stalled 4 times in 10 miles. Each time it wouldn't start right away and I didn't hear the fuel pump. Then I would try it and the fuel pump would kick on. "I noticed the pump part only one time. " It's now showing code 54. I'm not very familiar so I need some help.. Thanks to all...
Old 02-08-2005, 08:51 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: code 54.....Stalling Blazer
Search this forum and the blazer forum for CPI injector
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-09-2005, 09:24 AM
I don't think it's the injection spider. I thought fuel got into the oil when it was leaking... It could be the cpi regulator sticking, but I was thinking more fuel pump/relay related. I could be wrong though. I'm sure one time I didn't here the pump running when I tried to start it and then When I tried it again...the pump ran and it started right up. When it does start, it runs perfectly. Also, code 54 is computer malfuntion... what 's that about?
Old 02-09-2005, 09:38 AM
blazee's Avatar
blazee blazee is offline
Problem?
Code 54 indicates a problem with the fuel pump circuit.
Old 02-09-2005, 09:53 AM
What does that include? fuel pump and relay??? or the entire fuel delivery system.... Injectors back to fuel pump?
Old 02-09-2005, 09:56 AM
blazee's Avatar
Problem?
Try swapping out the fuel pump relay with one you know is good and try it for a while, if no more problems replace the bad relay.
Old 02-09-2005, 10:39 AM
blazee's Avatar
Problem?
Old 02-09-2005, 10:55 AM
blazee's Avatar
Problem?
Hope the picture helps....it took me 45 minutes to find a site that would host a 400k pic for free.
If anybody needs to post a large image you can use
http://www.image-hosting.ws
it's free and you don't have to register or sign up for anything
Old 02-09-2005, 02:12 PM
BlazerLT's Avatar
AF -Advisor
Hard starting in a CPI injection engine is more or less always the regulator not keeping fuel pressure up.
Check your fuel pressure and do a CPI injection system check by removing the top IMTV valve under the vortec plate on the top of the engine and look down inside the engine with a flashlight and look for golden washed spots and the smell and pooling of fuel.
Don't disregard my advice, I think I know what I am talking about.
Old 02-10-2005, 07:19 AM
I understand where your comming from on the cpi injector, but this was a fuel pump relay problem. Somehow a terminal was fried on my plug. Maybe from the old dying pump.. I don't know. It is fixed and going great.
Old 02-10-2005, 08:14 AM
blazee's Avatar
Problem?
Glad to hear it's going again.
Old 02-10-2005, 08:23 AM
blazee's Avatar
Problem?
You should probably do a little checking to see why it was fried. It could have been as simple as a loose connection or it may be a bad wire somewhere.
Old 02-10-2005, 11:44 AM
BlazerLT's Avatar
AF -Advisor
Also, it is best to check the CPI injector for leaking anyways.
They all become defective. It is just a matter of time. Heading it off early will save your engine from a lot of damage caused by fuel getting into the oil.
I strongly suggest you check for leaking anyways.
