Old 02-08-2005, 08:11 PM
Powerefx Powerefx is offline
Port Postioning?
Does it make a difference where your port is located in an enclosure? I mean will you get the same results if your port is on the top or bottom of the front of the box, rather than be on the side? Any upsides or downsides?
Old 02-08-2005, 08:38 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Port Postioning?
yes it does. you don't want port waves and sub waves out of phase. If you got a hatchback or SUV you can do subs up ports back.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-08-2005, 08:47 PM
SO the subs facing up, and the port facing the back of the car, or toward the rear seats?
Old 02-08-2005, 09:09 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Generally having the ports and the subs on the same plane is the best idea. In certain cars you can get better results by having them 90 degrees off, but in putting them on the same plane is the safest bet.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 02-08-2005, 09:36 PM
So in your opinion, if the sub and port were on the same plane, would it matter if the port was above, below, or to the side of the sub?
Old 02-08-2005, 09:44 PM
sr20de4evr's Avatar
no that wouldn't matter, just aesthetics
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-08-2005, 09:52 PM
what kinda car do u have?
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-09-2005, 12:04 AM
Ford Escort Station Wagon
Old 02-09-2005, 12:46 PM
subs and ports back will prolly be best.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 02-10-2005, 05:00 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Re: Re: Port Postioning?
And if you don't do that...or can't fit it correctly...
Go with the subs firing up, and the port firing back on the bottom of the box.
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
