Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-08-2005, 07:54 PM
cactuar167 cactuar167 is offline
cd player swap
Hello,
I just bought a Jeep Grand Cherokee 1996 limited and the in dash fm player does not work. My uncle works for daimler crystler and he said that they have problems with the cd player unit in the past.
I was wondering HOW to take my cd player from my 1999 plymouth breeze and swap it into my 1996 JGC. I looked around on the internet and it seems that some installation kits work for my breeze and grand cherokee...so im assuming that the JGC is compatible with my current kit. Are there any online tutorials on how to do this?
I just want to try this...it might not fix my problem but i want to know how to remove the player (from the JGC) and install the new cd player on the JGC. I think i know how to get the new player out of the breeze.
Thanks for your help!
Old 02-09-2005, 07:36 PM
jdennis jdennis is offline
Just changed mine out last night because the FM doesn't work, and if you look around, that is the HUGE problem w/that Infiniti system.
To take it out, no real fuss, just gently pop off the two fake-wood trim peices on either side of the steering column, then remove the 5 screws across the top of the instrument cluster, and the 4 on the bottom (2 on either side of the steering column). Then it should pop free (you might have to life upward on the heavy plastic dash area over the instruments to truly free the peice. After that, the old stereo is held in by 2 hex screws, just undo those and it will come right out. Any commerical mounting kit will help you mount the new stereo (if it is the standard slim one, if it is the thicker style I'm not sure how best to fit it). On the back of the infiniti is 4 sets of wires. The Feed Connector and the Speaker Connector will both go into an aftermarket/generic harness, but the ground plug doesn't. You can strip back the ground wire and insert it into this plug and then tape it up if you want. The other set of wires appears to be the connection to the computer console, so you should be fine ignoring that. Make sure that you DO connect the blue AMP wire whrever you find that on the harness because the Infiniti system has a factory amp under the back seat (in case you didn't know).
And I was happy to find that there is plenty of room behind the stereo for the wires for a change.
Old 02-09-2005, 08:57 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: cd player swap
Yeah, just yank on the plastic trim and 2 10mm screws hold it in. I personally wouldn't go through the trouble. A $140 Pioneer at Wallmart is better than what you are messing with.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
