Old 02-08-2005, 06:36 PM
smiths_33 smiths_33 is offline
Send a message via MSN to smiths_33
o2 sensor question
The SES light came on the other day so i took the car up to autozone to get it checked out. It said problem in bank 1 and that the o2 sensor was bad. I know there are 2 o2 sensors so which one really needs replaced? I don't want to spend the money and buy two so I need to find the bad one.
Old 02-08-2005, 07:39 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: o2 sensor question
from what i've read, usually the front o2 sensor goes bad...the one nearest the engine, sitting in the o2 housing. don't buy one from auto zone either...this is the one you want...
http://www.machv.com/denoxsen.html
Old 02-08-2005, 09:21 PM
MIne is a 97 2.0 non turbo. I didn't see one for mine.
Old 02-08-2005, 09:23 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
maybe if you put that info in your sig., we could help you out a little more.
Make
Model
Year
Transmission
Mods
95 Talon TSI AWD
97 Eclipse GST
Old 02-09-2005, 02:03 AM
kjewer1 kjewer1 is offline
AF - Advisor
In our case, everything will be "bank 1." With a v6 or v8, one side will be bank one and the other bank 2. I can't recall if the code says front/rear, but thats the terminolgy we use. If you are not getting a Catalyst System Efficiency Below Threshold (bank 1) DTC, odds are its the front sensor though. I would see if the code gives it away, if not, do the front if you arent also getting the above mentioned DTC.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
