Old 02-08-2005, 05:52 PM
george536's Avatar
george536 george536 is offline
speedometer not working wheres the fuse at?
My speedometer is not working or my milage moving. Theres a fuse for this right? where is it located?
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 02-08-2005, 07:21 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
I don't know about a fuse yet but, check behind your engine and look down at your transaxle and see if there is a connector loose. Hey it is what fixed mine. The guy said some how my shifter cables pull it out or when I got new cables they put it out.
....It has been a LONG time...I want to move to FL or Japan.....
Old 02-08-2005, 07:45 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Re: speedometer not working wheres the fuse at?
i never heard about a fuse for that, but check your "speed sensor connector", is really hard to see it because it's just under your intake manny on your tranny, so you may have to remove your battery, and try to see if it loose or not, i had the same problem, but in my case the speed niddle was jumping from 45 to 90 mph and doing strange things all the time, and that was because of my speed sensor connector.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 02-09-2005, 12:00 AM
macavelli04 macavelli04 is offline
Send a message via AIM to macavelli04 Send a message via MSN to macavelli04
mine on my old car done that and they checked it and said it was a little gear behind the tranny that wore out...they had to take out the tranny and put the gear in it...pretty pricey too...not the gear just the labor the gear was bout 30$...bullshit
Old 02-09-2005, 01:59 AM
kjewer1 kjewer1 is offline
AF - Advisor
There is no fuse. I would do as people suggested and check that connector. To be more specific, ona 2g its "inside" the rear tranny mount. There is a little plastic gear that mates with the front diff that could wear out, but that has to be pretty rare... 1Gs use a mechanical setup, so there is an actual cable going from the tranny to the dash.
Now that I think about it, I think the speed signal goes to the ECU, and the ECU drives the speedometer. So it could be a wiring issue there too. I cant be sure of that though. I know on the 1Gs, the cable drives the speedo, and the speedo has a magnetic or optical counter that sends the signal to the ECU.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-09-2005, 07:47 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I found a fuse under the dash for the gauge cluster. When I removed it the entire cluster went out (including the odometer). If I remember correctly, the power windows and locks went too. Check under the dash.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-09-2005, 06:45 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Re: speedometer not working wheres the fuse at?
There is no fuse for it. If you would look above people have said that. Yes by pulling the fuse out some lights will probably go out, but that is normal. The operation of the speedo is not related to a fuse. And...it is irrelevent that the odometer went out, as that is not really the issue at hand.
I believe when my electrical went out, everything in the gauge cluster did not work, except for the speedo, leading to the thought that is has nothing to do with a fuse.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-10-2005, 07:08 AM
Re: Re: Re: speedometer not working wheres the fuse at?
I know for a FACT that there is a fuse that controls, amung other things, the operation of the odometer.
1997 Spyder GS-T
5-Speed
Old 02-10-2005, 11:43 AM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
isnt there a cable for the speedo?
Old 02-10-2005, 07:29 PM
AF - Advisor
yes
Kevin Jewer
