Old 02-08-2005, 04:43 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Adding More Fuel
Just wondering if theres a way to add more fuel to the system without changing the pressure regulator, or rail etc etc....
my car runs lean once and awhile at idle and need to fine a way to add more gas so it does run lean
any ideas?
EDIT: is there a way to maybe trick the ECU to add more fuel? like maybe add a bunch of tees to the vaccum line for the pressure regulator??
Old 02-08-2005, 09:26 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
if you create a vacuum leak it will run nice and rich other than that, why not just get an fpr and gauge? Its pretty cheap and if your still planning on going turbo, you should have one anyways.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-08-2005, 09:37 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Adding More Fuel
If you're getting your reading off an autometer A/F guage with a stock single wire O2 sensor, your guage is probably completley inaccurate so I really wouldn't take it too literally.
You really don't need any more fuel for your ZC, its probably running rich as it is, but those autometer guages really aren't worth a shit.
If you want some accuracy you need to run a wideband O2, otherwise you're just getting a cute little light show.
"The nympho of info, I'm fuckin' what ya heard"
Old 02-09-2005, 12:47 AM
1PhatCX's Avatar
most ones i've seen are like 300 for the rail, and another 40 - 250 for the regulator, and right now i need to buy a new tranny
Old 02-09-2005, 08:09 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Adding More Fuel
I've been thinking I have the same issue, but then I think about your words of wisdom SiZ and I realize that I'm just paranoid. I noticed I run lean with my light show until the car has been running for at least 20 min. and if I use the heat or other electronics it'll be inaccurate. I'm throwing a code 1 but I don't run rich ever (according to my light show) but I don't smell bundles of burnt fuel either so I'm stumped. I've estimated that I've gotten around 28-30mpg recently so I'm not really going to worry about it...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-09-2005, 01:53 PM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
burnout more!!!!! theres trannies everywhere!!!!!!!!
and if u pay that much for a fuel rail and regulator you my son are one hell of a sucker
Old 02-09-2005, 03:59 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
the B&M regulator is only 35-45 dollars and another 30-35 for the gauge on ebay or even on websites!
Don't cheap it out and go the ghetto way.
Get an safc if you want to be able to adjust fuel at certain rpms...
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-09-2005, 04:33 PM
1PhatCX's Avatar
i'm trying to afford an SAFC but everytime i get money something fucks up!
Old 02-09-2005, 04:37 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
also, a rail is completly unneccessary until you are making major power.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 02-09-2005, 05:41 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
stock fuel rails good for 600whp
Team Lonely Drivers
Old 02-12-2005, 08:14 AM
bambam89lx's Avatar
AF - Advisor
got my safc on hondatech last month for $135 shipped. You just gotta pay attention to the deals and search the classifieds on multiple forums.
Old 02-12-2005, 08:40 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Not to steal the thread, but my car runs rich as shit, and I most likely have a vacuum leak. Think if I fix my vacuum leak, the car with lean out a little bit?
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 02-12-2005, 10:31 AM
no doubt. when theres a vacuum leak, vacuum pressure will obviously drop, just like when you have your throttle open. Your ecu thinks that the throttle is open so its dumping that much more fuel into the combustion chamber. An easy way to find a vacuum leak is to get something like carb cleaner, brake cleaner, whatever and spray around the engine near all the vacuum lines and fittings. if you hear the motor rev up at a certain spot, theres your leak.
ZC stuff
