Old 02-08-2005, 04:42 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
Changing battery on a 95
I'm helping my friend change the battery in his 95 PA. Problem is, I'm more of a Toyota guy, so I'm not sure how to do it. Looking at it, it's a lot different than my car (Toyota obviously). If anybody can give me a quick how-to, I'd appreciate it.
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 02-08-2005, 07:32 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: Changing battery on a 95
Um, wasn;t aware there was THAT much of a difference in batteries among carmakers.
Anyhow:
open hood
locate battery on passenger side, near front support member
using a 5/16 socket wrench( I like 1/4 inch drive) remove the negative cable(black)
using a 5/16 socket wrench, remove the positive cable(red)
The battery is secured to the tray with a 15 or 18mm bolt(can't remember which, I think 18) Remove the bolt and plastic trapazoidial shaped retainer.
Reverse to install.
Disclaimer: DO NOT TOUCH any metal on or off the vehicle while loosening or tightening the terminals. 12V of electricity will really wake you up.
Old 02-08-2005, 10:02 PM
Re: Re: Changing battery on a 95
Anyhow:
open hood
Reverse to install.
Thanks...it is a lot different than the Toyota. The yota battery is held on by a bar that goes over the top of the batter...couldn't see where the PA battery was being held on just by looking at it.
Old 02-09-2005, 05:04 AM
rotaran's Avatar
rotaran rotaran is offline
Send a message via MSN to rotaran Send a message via Yahoo to rotaran Send a message via Skype™ to rotaran
open hood
Reverse to install.
Wow, thats a real "step-by-step"-instruction.
Mike
1991 Buick Park Avenue
1995 Ford Fiesta
Waghaeusel/Germany
Old 02-09-2005, 06:26 AM
tman's Avatar
Pimpin' ain't easy
was it 15 or 18? I figured you had to be experienced with bars over batteries, GM's used this system for a while.
Mike-something wrong with that?
Old 02-10-2005, 01:48 PM
kaspr kaspr is offline
I believe it's 12mm, or maybe 13mm, at least it is on my '95 P.A. & '94 Bonneville as far as I can remember. And for the battery terminals I always used 8mm, though 5/16 is probably better. For the battery tray, you'll need a long extension for your ratchet.
