Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 02-08-2005, 04:31 PM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
ect
i have a 90 gts and is has a byutton in front of the shifter that says ect power/normal can anyone tell me whjat this does
Old 02-11-2005, 12:49 PM
Re: ect
Old 02-11-2005, 12:52 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: ect
It changes the shift points for the automatic transmission. The Normal position is best for gas mileage. The Power position delays the upshifts and gives better power to the wheels for driving in hills and such.
Old 02-11-2005, 05:14 PM
shsaint shsaint is offline
Re: ect
is that the same as the overdrive on / off?
Old 02-11-2005, 11:21 PM
Re: ect
oh thaty was obvious. thanks guys
Old 02-12-2005, 01:59 AM
Celica Tech Celica Tech is offline
Re: ect
It also changes how hard the clutches engauge when the tranny shifts. I sugest, unless you have granny in the car, keep it in pwr. Harder clutch engaugement means less slipping, less slipping means less ware on the trans clutches and fluid.
Old 02-12-2005, 04:07 PM
Brian R.'s Avatar
Resident Chemist
Re: Re: ect
No, the OD off just keeps the OD from engaging. The OD is just your top gear.
Old 02-12-2005, 04:10 PM
Brian R.'s Avatar
Resident Chemist
Re: Re: ect
This is interesting. I have not heard about this effect. Where did you find out about this? I don't doubt your information, but I am going to try and verify it from somewhere else.
Thanks for the new information
Old 02-13-2005, 12:12 AM
Re: ect
actually it does rev higher when the o/d is off in all gears and turns it into a 4 speed
Old 02-13-2005, 11:25 PM
Re: Re: Re: ect
I get this infromation from Toyotas technical information system, TIS for short, however only avalible for veiwing to toyota techs, this web based information site is full of all kinds of this type of information that you wouldn't be able to get anywhere elce exept from the maker of the product.
Also, if you get to test drive a car with ECT capabilties, hammer the throtle through the first 2 shift points when in normal mode, then try it in power. With the gas all the way to the floor it will rev out the gears all the way (unless your shift down cable is broken or not adjusted) even in normal mode, BUT you will notice it lets trans slip more. This is more so true in the newer cars than the older ones dew to trans and computer upgrades. Regardless I'll stop rambleing now.
Old 02-15-2005, 02:39 AM
Brian R.'s Avatar
Resident Chemist
Re: ect
Good - Thanks for the information
What year did the tranny start slipping more in normal mode?
Old 02-15-2005, 09:05 AM
Dont know the definates, but I do know from personal experence that back in 88 the supras with ect slipped more in normal, heck alot easyer to brake those wheels loose in pwr mode.
Old 02-15-2005, 06:57 PM
Brian R.'s Avatar
Resident Chemist
Re: ect
How about other Toyota vehicles, like trucks and Camrys?
