Old 02-08-2005, 03:57 PM
TOMMCCONATHY TOMMCCONATHY is offline
Trans Whines And Is Slow To Shift While Truck Is Cold.
79 C-10, 305, Automatic. 100k Miles. Trans Whines And Is Slow To Shift While Truck Is Cold. After It Warms Up, Shifts Better/good, And The Whine Goes Away. Whats Up
Old 02-08-2005, 04:01 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: Trans Whines And Is Slow To Shift While Truck Is Cold.
It is because it is cold. Let it warm up first.
All auto tranny's are slow to shift when their warm!!
Same thing happens with lockers and anything else that has to get warm first.
Let your truck get nice and warm before you go driving it.
Old 02-08-2005, 05:14 PM
I Found The Fluid Was Low When The Whine Developed. Should I Consider Changing The Fluid? I Read In Some Other Postings That Their Noise "was Not A Belt Problem". Could My Problem Be A Belt Inside The Trans Problem? If So, Can Belts (in Trans) Be Adjusted?
Old 02-08-2005, 05:40 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Well the fluid is probally going down and the trans whining due to the fact that it is not warmed up, my 93 shifts like shit when cold.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 02-08-2005, 08:02 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
A tranny that whines is usually from the front pump but that does not mean that the pump is bad.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 02-09-2005, 05:09 PM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
First thing to do is change the filter and fluid. That will solve a LOT of tranny issues.
Old 02-10-2005, 09:19 AM
I'm on the way to the store to get fluid, fiter and gasket today. I talked with a local trans shop and they recommened the same thing. They said I should look for metal or other particles in the pan. If a lot of stuff is in the pan, it probably means the trans is on it's way out. I'm hoping for the clogged filter and no mteal shavings senerio....
Thanks for the input.
Old 02-10-2005, 10:15 AM
Chevy-SS's Avatar
I've owned two gas stations and been working on cars for 30 years and changed plenty of auto trans fluid/filters. You will ALWAYS find some particles on the bottom of the pan. You may even find quite a bit of material there. It's normal and I would not be concerned unless the pieces are quite large.
Old 02-10-2005, 11:32 AM
TypeGsR TypeGsR is offline
Banned
lol
Old 02-10-2005, 01:42 PM
wHAT'S SO FUNNY TYPEGSR ??
THANKS AGAIN CHEVY-SS.
Old 02-10-2005, 03:00 PM
Chevy-SS's Avatar
I guess my comment about the pieces being "quite large" could be kinda funny. I mean, if it's pieces of gears and such, well then, yeah, you gotta serious problem.
Funny thing is, I've done plenty of trannies where the pieces really have been large, some of them on my own, lol.
Old 02-10-2005, 10:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
When I pulled the pan on a friends car, I think there was enough metal shavings to fill 20 of those "Wooly Willy" game things... tranny has been fine, going on a year now.
Old 02-14-2005, 03:41 PM
Well, I Changed The Fluid And Filter. It Made A Big Improvement In The Way The Trans Sounds. No More Whine, And It Shifts Better As Well.
In The Pan, Was About 1/4" Of Fine [maybe Even Metalic] Sludge. I Wiped It Clean And Put It All Back Together. We'll See What Happens Next...
Old 02-14-2005, 08:18 PM
Chevy-SS's Avatar
Lots of metallic particles is normal. The clutch packs and bands in the transmission are made out a material similar to a brake pad. As such, they wear down. For instance, you typically see brake dust on your wheels (unless you have the expensive pads) as the brake pads wear down. The same thing happens in the tranny except the worn material cannot escape the transmission case, so it settles to the bottom of the pan and eventually clogs up the filter.
Old 02-16-2005, 08:35 AM
Thanks. I Was A Little Worried That This Better Operation Would Be Very Short Lived. Someone Told Me That If There Was A Lot Of Metal In The Bottom Of The Pan That The Trans Might Work Better, But For Only A Short Period Of Time. I Know It Won't Last Forever With The Bands And What-not Loosing Their Materials, But Hopefully It Will Last For A Couple Thousand More Miles. I'm Glad I Found This Web Page With The Good Feed-back I Have Received. Thanks Everybody.
