Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-08-2005, 03:45 PM
pacmanpapaw pacmanpapaw is offline
2000 chevy suburban remote
I just purchased a used but in good condition chevy suburban remote for our 2000 chevy suburban, does anyone know how to program, I looked in my manual and followed the directions but the remote didn't work, HELP!!!!
Old 02-12-2005, 07:27 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Make sure you have the right remote for your application. There are alot of remotes that 'look' the same but what counts are the GM/LEAR# and also the FCC ID#.
I would suggest you take your VIN# to your dealer and see if they will give you the correct numbers for your vehicle. You then can purchase the remote off of Ebay for somewhere around $10. Then try to reprogram.
Good Luck,
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 02-12-2005, 12:16 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 2000 chevy suburban remote
Transmitter Programming Base Model:
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
1. Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
2. Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
3. Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
4. Remove the ground applied to the DLC.
5. Lock and unlock the doors in order to verify the transmitter operation.
6. Activate the rear window release in order to verify the transmitter operation.
Method for Higher End models:
Have each of the transmitters that you intend to program ready. This vehicle will allow you to program a maximum of four transmitters programmed at one time.
Turn the ignition to the RUN position, then back to the OFF position. This will disarm the theft-deterrent system.
Remove the RADIO fuse (Fuse 17).
Turn the ignition from the OFF position to the RUN position three times quickly, within five seconds. The vehicle will respond by locking the doors, unlocking the driver's doors and releasing the tailgate or panel doors. The transmitter is now ready to match to the vehicle.
Press and hold the LOCK (1) and UNLOCK (2) buttons on the first transmitter for 15 seconds. The vehicle will respond as in step 3.
Repeat step 4 for the remaining transmitters.
Replace the RADIO fuse.
Check that all transmitters work by pressing their buttons.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
