Old 02-08-2005, 03:24 PM
jazzman143 jazzman143 is offline
1995 Park Avenue DLC
Hi!
Forum virgin here. I have a big belly, which is probably why I'm having a difficult time finding the Data Link Connector. I've read it is at the base of the passenger side of the steering column. Can someone supply a picture or be more specific about what I'm looking for (looks like, how it's mounted). Do I need to remove anything to see this?
Thanks,
Bill
Old 02-08-2005, 04:43 PM
volkerc's Avatar
volkerc volkerc is offline
Re: 1995 Park Avenue DLC
Originally Posted by jazzman143
Hi!
Thanks,
Bill
You don't have to remove anything, it is a black square plastic connector, about 1 by 2 inches in size. It is sticking out from behind a cover underneath the dashboard. It is to the right side of the steering column, close to the gas pedal, so you have to really lay down under the dash to get a good view. I move the driver seat all the way back to get good room...
I'll try and post a link with a little more info.
Old 02-08-2005, 04:46 PM
volkerc's Avatar
here is one link with some info...
http://uuhome.de/pr-meyer.h/aldl.htm
Old 02-08-2005, 04:50 PM
volkerc's Avatar
and another useful link...
http://www.gnttype.org/maint/malf.html
Old 02-08-2005, 05:32 PM
Smile 1995 Park Avenue DLC
Thanks for your response Volkerc. I have your description and I went to both links you supplied. I now have a good picture of what I am looking for. The diagrams label the pins A to L. This bring up another question. What I need the link for is to program a keyless remote I just purchased. I have been told to short pins 4 and 8 (with a 3 amp fused wire). Do I substitute the letters for numbers 1 through 12, or is the ALDL
something different from a DLC? I'm going to go take a look in the car now.
Old 02-09-2005, 02:41 AM
volkerc's Avatar
I'm pretty sure that you substitute the letters with numbers. I do have a 91 and I had to jump letters a and h. Now I'm not sure if programming the remote might be different on a 95. I checked in my 91 manual where they also gave direct instructions on how to program the remote. You might want to check your owners manual also, just to make sure...
Old 02-09-2005, 01:46 PM
Re: Re: 1995 Park Avenue DLC
OK volkerc
As you suggested, I found it in the users manual. I didn't think to look there because this is more of a repair issue, and had no luck there whene I tried to open up the dash. In my case the DLC is a 16 pin connector, they say, above the gas peddel. I still can't find it. I see some kind of connector above the break and kind of loose, but I'm not sure. I guess I'll just take it to the dealer.
Thanks again for all your efforts VOLKERC.
Old 02-09-2005, 04:58 PM
volkerc's Avatar
Re: Re: Re: 1995 Park Avenue DLC
OK volkerc
thats what i thought you had 16 pin connector...
maybe you are confused what you are looking for. i'm pretty sure you know what an old printer cable for a computer looks like, now think of the opposite part on the computer, where you push the printer cable in, now on your car your looking for something similar, looks and sizewise.
i had to look a few times myself, because the connector is black, blends in nicely with the dash panel, the connector you saw is probably what you were looking for, i assume...
Old 02-10-2005, 10:08 PM
Re: Re: Re: Re: 1995 Park Avenue DLC
Hi volkerc
Took it to the dealer to confirm our suspecion. It is the one. They wanted $35 to make life easy for me. I just couldn't do it. I'd rather give it to a friend. Your also right that it looks something like an old TTY connector. I fixed computers for 20 years. You seem like you have some experience in the area. Thanks again pal.
Bill
Old 02-11-2005, 12:00 AM
volkerc's Avatar
Re: Re: Re: Re: Re: 1995 Park Avenue DLC
Hi volkerc
Bill
No problem,anytime....
Old 02-16-2005, 12:49 PM
lglm lglm is offline
Re: Re: Re: Re: Re: Re: 1995 Park Avenue DLC
be aware that my 95 connector was upside down in relation to the pinout in the owner's manual...
