Old 02-08-2005, 04:17 PM
bennetr bennetr is offline
93 Voyager 3.3l engine shutting off
Engine shuts off after running for about 45 minutes to an hour. Short trips, runs fine. Anything approaching an hour, it will shut off. No sputtering just shuts off. Decided to let it sit in the driveway and run, sure enough after about 45 minutes it shut off. Will not start up right away. Turns over but acts like there is no fuel. Let it sit for an hour, starts right up and will go for another 45 minutes or so. Fuel pump has been replaced. Any ideas???
Old 02-08-2005, 09:12 PM
Alphabravo Alphabravo is offline
Sounds to me like one of the sensors is having a thermal breakdown. Could be the crank sensor, cam sensor, you name it. Best thing to do is take it to Auto Zone for a free ECM scan and find out what trouble codes are stored in there. That may point to the culprit. Good luck.
Old 02-08-2005, 11:06 PM
caravandrvr's Avatar
caravandrvr caravandrvr is offline
I'd bet it is the cam or crank sensor.
