Old 02-08-2005, 02:57 PM
St.Anger561 St.Anger561 is offline
Fix a flat and ground effects
Hey I am new, whats up everybody. I got a ? , I put some fix a flat in one of my Z rated Potenzas, I guess that is a no no, anyone know about this? Also I got ground effects on my 99 GT, I keep grounding out and my oil pan is coming down, what a pain, any suggestions...thanks in advance.
Old 02-08-2005, 04:01 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Fix a flat and ground effects
As far as the fix-a-flat, just take it to a tire place and they can pull it apart it, clean out the fix-a-flat, and fix any leaks for probably 15 to 20 bucks at most.
As far as the ground effects, if you keep bottoming out, you might be able to use inserts or something to raise your spring height. Not sure. run a search on www.grandamgt.com and you might find something.
Old 02-08-2005, 06:08 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Yeah, ridenour's right on the fixing a flat price. I'm gonna say this though, you probably bought z rated tires for a reason: to drive fast once in a while. As far as I'm concerned for your safety and the safety of others on the road, that tire is done for. If the the tire was just being to putt around on at normal speeds then sure have it patched, but if your going to speed in it, in my opinion I wouldn't suggest fixing it. Again this is just my opinion.
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
Old 02-11-2005, 07:42 AM
Knifeblade Knifeblade is offline
I kinda follow fork's thinking, fix-a-flat is really for slow leakers and low speed running. It is NOT a permanent repair. And, as you say Z-rated, chances are ya want to scoot at times. I wouldn't do that on a tire with fix-a-flat.
