Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-08-2005, 09:20 AM
bowhunter1432's Avatar
bowhunter1432 bowhunter1432 is offline
crazy??
how do i get the tire on this talon off it has a cotter pin,do i take that out and then take out the huge bolt on it?i took off all the nuts and still it doesnt come off i feel like chump lol,i have several trucks and never have a problem lol.
2000 Chevy Blazer
1995 Talon
Old 02-08-2005, 10:42 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: crazy??
I am not sure what you are asking. You want to take one of the wheels off. Unless the talon wheels are different than any other wheel I have ever seen, you just have to remove the lug nuts. The cotter pin/big nut combo houses the wheel bearing (At least it does on most cars). If you have removed the lug nuts and still can't get the wheel off you may want to try and wiggle/kick it. It may be stuck. Sit on the ground and give the bottom of the tire a good kick towards the car. That should break it loose. DISCLAIMER: Make sure you have the car on jack stands or something similar so you don't kill yourself.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-08-2005, 11:01 AM
Re: crazy??
ok thanx maybe it is stuck lol.
2000 Chevy Blazer
1995 Talon
Old 02-08-2005, 11:02 AM
Re: Re: crazy??
Let me know how you make out.
1997 Spyder GS-T
5-Speed
