Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 02-08-2005, 10:10 AM
johnsnow22 johnsnow22 is offline
Arrow turn signals
Hi, I have a '90 Bonneville with no turn signals. I checked the fuse and replaced all the bulbs. Please tell me it's not a wiring thing.
Old 02-10-2005, 09:29 PM
randman1's Avatar
randman1 randman1 is offline
Re: turn signals
Have you checked the flasher yet? Turn your hazards on to verify that that flasher is working properly. If it is then substitute the hazard flasher for the turn signal flasher. If the turn signals work then you've found the problem. Both flashers are located behind the trim panel under the steering column. Turn signal flasher on the left and hazard flasher on the right side.
What trim level os your car and what fuse(s) have you checked already?
Old 03-01-2005, 05:23 PM
Re: turn signals
it was the flasher thx
