Old 02-08-2005, 09:09 AM
pauper_72 pauper_72 is offline
Angry 4.3 vortec 4x4 engine / fuel issue
99 S-10, 170,000 miles
New mechanic here guys so be gentle. I am getting two P0-300 codes from my truck. "Multiple / Random cynlinder misfire detected". Starts cold, then misses BAD as it warms up. It tries to stall, corrects itself for a few seconds and repeats. However, this truck runs smooth as a babies arse with even the slightest pressure on the gas pedal. Just misses at an idle!!! And, there is no hesitation in reving at first depression of gas pedal.
I changed the pickup coil, plugs, wires, o2 sensors. It seems like a fuel delivery issue but doesnt make sense that it only happens when it is warmed up. It smells real rich when first started, but no smoke. I was thinking maybe a throttle sensor or something fuel related.
Thoughts? Oh, and after it stalls, I have to floor it to get it to start up again. Almost like it is flooded. Also, what is meant by "computer goes through a complete drive cycle" to clear a code (I use a handheld and "erase" codes when done).
How can I determine what cylinders are the problem? I tried to unplug wires and arch the spark on each cylinder, but it is a random thing.
Old 02-08-2005, 09:30 AM
vtmecheng vtmecheng is offline
Re: 4.3 vortec 4x4 engine / fuel issue
Do you have a haynes manual for your truck?
Old 02-08-2005, 09:33 AM
yes. But it doesnt tell me anything other than what the code is, which is also displayed on my "code scanner"
Old 02-08-2005, 09:49 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
I had similar problems, and it was actually a battery terminal coming loose. I would have to slightly apply the gas to keep the engine from stalling out or idling at 300 rpms. Especially if you have aftermarket terminals, I would check them and your battery cables first.
Old 02-08-2005, 10:20 AM
Ignorance on my part, and trying to learn this stuff so...
How would loose battery terminals cause cylinder misfires? I thought the engine ran off the alternator.
Again, I managed to change my old 92 4x4 4.3L Blazer motor by myself, but this is CRAZY!!
Old 02-09-2005, 01:41 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Sounds like a fuel problem to me if it clears up when you touch the gas.
Changed the fuel filter lately?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-09-2005, 06:26 AM
Random Cylinder Misfire means one of the sensors, like crank or knock sensor, detected a hickup. This hickup can be caused by a lot of different things. Change your fuel filter first, always a good thing to do on a high milage vehicle. Take some fuel injector cleaner, Techron stuff (guys on Tahoe section have this problem all the time and say Techron is only way to clear it up), put it in the tank and fill with only 12 gal of gas. Let us know how this works and we can go from there. Good luck.
Old 02-09-2005, 02:04 PM
BlazerLT's Avatar
AF -Advisor
P0300 is usually related to a fuel or spark problem 95% of the time.
A good fuel injection cleaning will usually fix it up or a new fuel filter or a fuel pressure regulator.
Seeing you have pretty well replaced the whole ignition system, I would be leaning towards the fuel.
Too bad you installed all those new parts when most of them were probably in good shape.
Old 02-09-2005, 04:41 PM
Hi. Ok, filter changed. PVC valve changed. Not helping!
Is there a way to check any further issues before I have to take it to a dealer and have them charge me $100 for diagnosis?
I also put in a bottle of cleaner techtron and ran it at a higher idle (2500 rpm's) for about 10 minutes. Does it normally take longer, if so how long? I can drive it around if it speeds things up a bit.
Would the injectors be diagnosed by a fuel pressure check? I can get ahold of a pressure gauge for fuel systems. If I used cheaper plugs, could it be that they are not burning as hot or causing this also?
Old 02-09-2005, 08:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Possibly the IAC (Idle Air Control)? Have you cleaned the throttle body and IAC passage?
Old 02-09-2005, 09:54 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 4.3 vortec 4x4 engine / fuel issue
No, an IAC will not cause a P0300.
I would check fuel pressure.
Old 02-09-2005, 11:46 PM
Thanks! I will get the guage and check tomorrow, oh tomorrow is today, and let ya know the readings. Is correct (or adequate) pressure 60-65?
Old 02-09-2005, 11:49 PM
BlazerLT's Avatar
AF -Advisor
61-66psi with the key at the first position.
Do not start it and then put the key back to that position, go from off to the on position for the proper fuel pump priming sequence.
Old 02-23-2005, 10:21 AM
Hi - Finally got around to checking pressure. Without starting the truck and with the key in the ON position pressure was 55. After starting it, pressure was 59. I hit the "release" button a few times and it never went above 59.
Is the best place to start the fuel pressure regulator?
Old 02-25-2005, 03:48 PM
Hi again.
OK, FINALLY found the fuel pressure regulator (who's bright idea was THAT???) and changed it.
It did not help AT ALL. The truck will run great at RPM's above 1800 FOREVER with no MIL codes. Under that, it chugs and misses for about 4 minutes before 2 PO300 codes come back.
Any thoughts?
