Old 02-08-2005, 07:53 AM
KENNY GUIDO KENNY GUIDO is offline
96 Firebird Keyless Entry?
I recently picked up a 96 firebird. The sad thing is that I know very little about them. I more accustomed to the 80's chevys. It seems that I keep reading that there is a keyless entry remote that is supposed to come with the car. I didnt get one with mine. not sure if it ever had one or what. Can someone please tell me if mine does or is supposed to?
Old 02-08-2005, 08:21 AM
pontiacpmpn's Avatar
pontiacpmpn pontiacpmpn is offline
Send a message via AIM to pontiacpmpn Send a message via MSN to pontiacpmpn Send a message via Yahoo to pontiacpmpn
Re: 96 Firebird Keyless Entry?
I think that it should come with it. It is an option on some cars, but most come with them. If you do find out that you are supposed to have one, you can get another one at a pontiac dealership or off ebay, and have it programmed to your car. The dealership would also probably be able to tell you if your car was supposed to come with one...
|1979 Firebird Formula W/T-Tops | 1997 Saturn SC1 | 2001 Harley Davidson Sportster 883 |
Old 02-08-2005, 08:25 AM
THANKS! Would they be able to tell with the VIN number?
Old 02-08-2005, 09:00 AM
Yea, they could look up the vin number, I think they should be able to tell by the model too.
Old 02-08-2005, 09:56 AM
Re: Re: 96 Firebird Keyless Entry?
i called before and they said my car is equipped with it. The thing is that for a remote, they want $61 from the dealer. Now, i looked on ebay and they have them thier pretty cheap, but there seems to be different styles. do they all work? they said i would have to bring my car in so they can program it at the dealership. should i get one from ebay?
Old 02-08-2005, 11:17 AM
Re: Re: Re: 96 Firebird Keyless Entry?
They will all work if you bring them to the dealership to be programmed, as long as they are for the same car.. different car companies will use different frequency settings... so just pick one up for a 96 Firebird, and it shouldnt matter what style it is. The dealership will be able to program it to your car. Its up to you where to buy from, if you buy from ebay it will probably be used, so keep that in mind.
Old 02-08-2005, 11:41 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
1996-1997 Keyless Entry Programming
Programming procedure:
  1. Turn ignition switch to OFF position.
  2. Remove RADIO fuse 17 from fuse block.
  3. Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode.
  4. Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds.
    1. Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding.
    2. Any transmitter code that was previously programmed has been erased.
    3. Body Control Module is now programmed to remote control door lock transmitter.
  5. When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled.
  6. Ignition switch to OFF.
  7. Reinstall RADIO fuse 17 to fuse block.
Also if its listed for your year on ebay or if its from the same year/model. It will work. Good luck.
John
Also welcome to the forum.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 02-09-2005, 06:33 PM
LE12345671's Avatar
LE12345671 LE12345671 is offline
Send a message via AIM to LE12345671
Holy crap... how do you know all of this shit? I am impressed
Old 02-09-2005, 06:47 PM
FormulaLT1's Avatar
Fight the powwa!!!
In my spare time I pass along car knowledge, My fulltime job is being a god though.
Supermod
Old 02-09-2005, 11:21 PM
LE12345671's Avatar
So that's y u answered knightrider when he was saying "oh god" last night?
Old 02-28-2005, 09:47 AM
F1r3b1rd F1r3b1rd is offline
FormulaLT1, thanks for that info! I havent used my keyless entry in three years, my drivers side key cylinder was damaged in break in attempt recently. Now I can wait till its warmer to replace it.
Old 02-28-2005, 10:04 AM
FormulaLT1's Avatar
Fight the powwa!!!
No problem, good Luck. Let us know how it turns out.
John
