Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-08-2005, 03:01 AM
oly1oly oly1oly is offline
'98-Key does not come out when turned off
I have a 98 Achieva and sometimes when it is turned off the key does not turn all the way off and cannot be removed. I have read somethings about a passlock and something about fuses under the hood. my fuses are good, and I'm not sure about the passlock. After a few minutes I hear a click from the steering column and can turn off and remove the key. This is really annoying any help would be greatly appreciated. Thanks oly1oly
Old 04-01-2005, 02:53 PM
Re: '98-Key does not come out when turned off
For all that may be interested it finally happened. The key would not come out at all I had to disconnect the battery to keep it from draining. I removed the steering column cover and there is a white ignition lock with a brass colored button on the back of it I pushed on it and the key released. I still have not figured out what the problem is. I was told it is a theft deterent ignition lock. I removed it and key operates fine. New ign lock cost 35.00 not sure if that is the problem.
Old 11-17-2006, 11:33 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
you only had to pay 35 for a new lock ??
wow they are 175 bucks here
dang thats not fair lol
the key cylinder lock that is
mine was doing that for a while even with the new lock in it but i just got rough with it and manhandled it to make it turn back when i wanted it to and now it turns back all the way just fine no problem finally
so i dunno
also my auto shifter is a real pita to depress the button and shift, it is a real struggle to get it out of park usually
these achievas have so many issues its insane..
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Closed Thread
