Old 02-08-2005, 12:19 AM
rjmead86 rjmead86 is offline
Road Noise
96 Caravan used to be quiet - now I hear what sounds like tire noise. It started suddenly on a trip. Everything still runs fine. Can something happen to tires so they start making noise - or is it mechanical
Old 02-08-2005, 03:53 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Road Noise
tire noise is the number cause of road noise. How long have you had your set of tires?
Old 02-08-2005, 10:25 AM
Re: Road Noise
I've only had the van for a couple months - Funny thing is it was quiet - I pulled into a gas station and checked the tires - pressure was about 25 in all 4 - I put it up to 30 and then the noise started. Put the pressure down again - doesn't help. Tires look good - maybe 25% wear. I've heard loud tires before, but I wonder if a seperation or something can suddenly cause a tire to get noisy? ...Thanks for your response
Old 02-08-2005, 01:31 PM
yeungra yeungra is offline
Re: Re: Road Noise
Then you should check whether it's coming from tires or the chassis, like bearing noise.....
