Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 02-07-2005, 11:59 PM
Vetteman84 Vetteman84 is offline
skyline engine in daytona, will it work?
I am looking around at different ideas for a new engine and tranny in my 87 daytona. I have found a good deal on a skyline engine and tranny, but i'm not sure if it will fit in my daytona. i know some modifications would have to be done, but does anyone know if it is possible?
Old 02-14-2005, 02:26 AM
DodgeDaytonaV6 DodgeDaytonaV6 is offline
werent skylines rwd? daytona's are fwd... dunno if it will work.. but then again, with enough money... anything will work...
1990 Dodge Daytona ES (Parts) | 1993 Dodge Daytona ES (DD/Project Car)
Doing/Done:
4 Wheel Disc Conversion (In progress)| 5 speed manual swap (In progress) | 52 mm Throttle Body | K&N Air Filter
Soon to come:
Underdrive Pulley System | Port & Polish Heads, Intake & Exhaust manifolds, and plenum | 0.040" Venolia Forged Pistons |
3" Catback exhaust (custom mandrel bent) | Custom exhaust manifold and crossover pipe | Garrett TO4E 57 trim | Walbro 255 lph Fuel Pump
Old 02-14-2005, 10:36 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yeah, you can make it fit if you have the time and money. However, you're going to have to completely work over the front end and the suspension since the RB26DETT is a much heavier engine. Your car won't handle right if you don't.
Old 02-17-2005, 12:57 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: skyline engine in daytona, will it work?
I thought Skyline engines were SR20?
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 02-17-2005, 03:52 PM
dita0401 dita0401 is offline
Banned
just put daytona badges on the car and swap the vins out and call it done. you'll have a rwd tona w/ a skyline engine. simple
Old 02-17-2005, 07:40 PM
Polygon's Avatar
The Red Baron
Re: Re: skyline engine in daytona, will it work?
Nope, the Skyline got a 2.6L I6 not a 2.0L I4. I think the SR20 went in the 240.
Old 06-20-2005, 02:45 AM
99grandgt's Avatar
99grandgt 99grandgt is offline
Send a message via AIM to 99grandgt Send a message via Yahoo to 99grandgt
hey, with caravan suspension parts, modified k member, and a B.F.H., you can put a smallblock and 904 or 727 tranny in that beast, and call it a day. the whole thing would cost like 5000 grand to do w/o motor/tranny. if you shop around it could be. there were at one time kits you could purchase for this swap, but not anymore. browse around for ideas on this, cuz even a mild 318 in a daytona would haul ass. thanks for listening, and never again mention a nissan motor molesting the mopar ever again!!!! just kidding
"haze grey and under way!!!"
99 honda odyssey
99 grand prix gt
possibly a g8 gt when i get to cali
Old 06-20-2005, 01:10 PM
AWP9521 AWP9521 is offline
How about swapping on some DOHC 4 valve Neon heads on it, I have read some articles saying the heads will bolt right on the 2.2/2.5 blocks but need to be modified for oiling the valvetrain and drainback, different timing bels, etc. Some stuff I have read that in turbocharged apps they can make a ton of power somewhere up into the 400-500 HP range.
Old 08-10-2005, 04:38 PM
2.2shelbydodge 2.2shelbydodge is offline
Well heres the funny thing i know a guy who has the rwd adaptor plates to make the daytonas into rwd. the other thing is that an "A" body rearend will slide right into the rearend area its not a cheap conversion.
the guy did it to one of his cars and got the little bugger into the 13's stock (89 t2 daytona)
another helpful site is www.turbododge.com lots of great info there.
cyas later
Old 09-19-2005, 10:04 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
Where theres a will theresa way, anything can be done to a car with the right imagination/handywork behind it.
Old 11-03-2005, 02:22 AM
no, the skyline engine is not the sr20, they put that in some sentra's
Old 11-29-2005, 11:51 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
why might i ask would u want a skyline engine in a daytona ? thats just asinine, it is not like the car is gonna be any better- maybe rev higher but u can send the computer out an have it rev out to 8,300rpm which would be pointless unless u got the engine worked which if u work it u might as well supercharge/turbo it, that would be more economical an a hell of alot cheaper... i dont even think u will get much more power outa the 2.6 - just do a 3.0 conversion, or if its the rwd u want then go for something that makes all that modifying worth it- an throw a hemi in it which has been done before an i witnessed it on the drag - u couldnt even tell the car had a huge 8 in it - cept the roar of the exhaust- it ran 12.1 with out nitrous or any force induction.
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 11-30-2005, 11:53 PM
Yes, true but a skyline engine will be much quicker
Old 12-01-2005, 07:27 PM
thats only cus of the trans thats in it - if u have your gear ratio's changed - you can make others things just as fast if not faster - without having to spend like 20k on a swap job
Old 12-13-2005, 09:10 PM
davida6302 davida6302 is offline
Actually a sr20DET is a skyline but the main thing you will need is besides money will be the complete wiring harness without that you will need alot of books and time, I did a swap in a 240sx was fun to do and is lots of fun to drive...high 12's 1/4 mile time. Good luck
