Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-07-2005, 09:43 PM
alvarezm alvarezm is offline
Send a message via AIM to alvarezm
1g PROBLEM NEED HELP!!!!!
I have a 91 Eclipse GSX its had a problem before with just shutting off when i'm going slow or idling, i thought it was just that the fuel pump harness was loose, i had taped it up with some electrical tap and it worked fine, but recently i was driving and i when i was accelerating i could hear a slight whining or a hissing sound, i just thought maybe i just never payed much attention to it, when i slowed down to park it was starting to hesitate slightly, i had to keep reving it up so it wouldnt try to shut down, when i parked i let it idle for a little bit to see if i could figure out what was wrong, it never shut off but would start bogging out when idling and then come back up to about 1300rpm and then start to bog out again, i could hear hissing coming from the engine compartment but i wasnt able to determine where it was coming from. My car has no catalytic converter, 3" downpipe and 3" exhaust, Air fuel controller, greddy boost controller set at 15 psi, greddy turbo timer, k &n intake filter (the air box isnt sealed properly some of the clips are missing), 255lph fuel pump and 680cc injectors, it was dyno tuned by a reputable shop....anyone have any idea what this might be, any help would be appreciated, thanks.
-Mike
Old 02-08-2005, 08:40 AM
RSLaser RSLaser is offline
fuel pump harness
Do you mean you taped it to the tank? There should be bolts. And the whinig sounds like youve got a vaccuum leak.
1991 Plymouth Laser RS
Only sat for a few years....
Old 02-08-2005, 11:32 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: 1g PROBLEM NEED HELP!!!!!
Venting your blow off valve? Have you checked for boost leaks?
Kris
2012 Genesis Coupe 2.0t
Old 02-08-2005, 03:12 PM
the harness, not to the tank, just the two connectors that go into the tank, i also just discovered that the screw on top of the throttle body is missing, so i believe that this has something to do with it, but i'm not sure, it wont even start at all now, any ideas?
Old 02-08-2005, 03:13 PM
Re: Re: 1g PROBLEM NEED HELP!!!!!
yeah, bov is venting to the atmosphere (turbo xs bov rfl-h) havent checked for boost leaks yet, car wont start at all now, throttle body screw is missing...
Old 02-09-2005, 10:05 PM
1Fast_Tsi's Avatar
1Fast_Tsi 1Fast_Tsi is offline
the same thing happened to my brothers dsm, you need to get a tb screw and it should start, just put your finger over the whole and have some one try to start it, it that does not work then i dont know, thats what we did to my brothers car and it started then we just got a screw and it works fine.
Red 90 tsi AWD 5speed
Love KIllin those V8's!!!!!!
Check me out at www.cardomain.com/id/1fast_tsi
Old 02-09-2005, 10:36 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
If your air metering system is stock, you should not vent your BOV
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 02-10-2005, 07:57 AM
Exactly where I was going with my question.
Kris
Old 02-15-2005, 03:19 PM
macder macder is offline
Send a message via MSN to macder
As for your throttle body screw missing, the part # @ mitsubishi is MD614948.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 08-27-2005, 12:29 PM
Bodack Bodack is offline
Send a message via AIM to Bodack
Meaning that if you had something like the GReddy E-Manage you would be able to vent it?
Old 08-27-2005, 03:48 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
This thread is 6 months old. Start a new thread if you want a question answered.
