Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-07-2005, 09:41 PM
macavelli04 macavelli04 is offline
Send a message via AIM to macavelli04 Send a message via MSN to macavelli04
car shaking when driving.....
my 99 eclipse gs shakes when im goin around 60-up mostly when i press on the gas and turn the wheel...i dont kno what it is..i had a few people checki t out and they dont kno...they thoug tit was the control arm but i got it changed and it wasnt...help!
thanks
Old 02-07-2005, 09:45 PM
carlos80 carlos80 is offline
Re: car shaking when driving.....
have you check your tires
how about your wheels were they balanced with the tires you have on now
Old 02-07-2005, 09:53 PM
Livid's Avatar
Livid Livid is offline
Ya make sure u check to see if the tread on your tires is wearing evenly if you notice uneven wear you'll need an alignment to correct the problem
1995 EAGLE TALON ESI
Eclipse Conversion Kit/Bomex Side Skirts/BMX Rear/Blitz Front
17" Rims/Yokohama Tires
Pearl White Paint
CF Hood/CF Tail Lights/Headlights
Aftermarket Spoiler
Cat Back Exhaust
50 hp Shot Nitrous/Side purge system
Aftermarket 12psi Stage 3 Turbo
Cold Air Intake/Greddy Intercooler
S3 Racing Chip
Front/Rear Strut Bars
Short Shifter/Racing Clutch
APC Racing Seats
Navy Blue Carpet
Dual Guages/Custom Paint
Alpine/C7 Sound System 3 12" subs in custom trunk box
Old 02-08-2005, 08:36 AM
RSLaser RSLaser is offline
Are you hard on the brakes? Disk warp causes it too.
1991 Plymouth Laser RS
Only sat for a few years....
Old 02-08-2005, 09:01 AM
my back tires have been wearing out really fast for some reason...i had them aligned but they still wear out fast. im not too bad on brakes..it helped some last time i got new ones and my rotors turned but still didnt fix the problem...
Old 02-08-2005, 10:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
if you had the brakes re-done recently the only other thing it could be is tire balance. an alignment won't really solve a problem because a car will still ride smooth if there is excessive caster/camber/toe. get your tires balanced and get a total alignment (all 4 tires) if they aligned it properly, they should not be wearing anything visible to eye, unless you drive 1000 miles a day.
95 Talon TSI AWD
97 Eclipse GST
Old 02-08-2005, 11:56 PM
aight ill do that and get back to ya...
thanks
Old 02-14-2005, 09:08 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
how about cv joints? had them checked lately. i know my dads car bounced around at the same speed. bad joint can cause some shaking
Old 02-14-2005, 09:27 PM
ill try that too...im gettin it 4 wheel aligned wednesday and ill let yall kno...imma tell them to check it out if they dont charge too damn much...it is the dealer thats doin it...damn its gonna be too much
Old 02-14-2005, 10:52 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
So dont take it to a dealer. Problem solved.
As for the CV Joint, I am doubtful. Mine is pretty shot right now and I do not experience any shaking.
"You can have everything in life you want if you will just help enough other people get what they want."
