Old 02-07-2005, 08:37 PM
'89sdimeblazer '89sdimeblazer is offline
squeaky
my front end squeaks when i hit a bump or turn so i greesed the front end and shit, think it might be the shocks ne input?? thanks
Old 02-08-2005, 03:04 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: squeaky
did you grease all 11 fittings?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-11-2005, 11:52 PM
Re: Re: squeaky
i thought there was only 6??
Old 02-11-2005, 11:54 PM
BlazerLT's Avatar
AF -Advisor
Re: squeaky
Nope, 11
Old 02-12-2005, 06:15 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
inner outter tierods, both sides (4)
pitman arm
idler arm
upper and lower ball joints both sides (4)
both u-joints (only if after market, OEM doesn't have any zerk fittings) (2)
(Total=10-12)
Another possibility are worn sway bar bushings... Pull, grease the pad, reinstall.
Check for play/cracks/dry rot in your control arm bushings, common issue.
Check for dry rot in your body mount bushings
Old 02-12-2005, 12:38 PM
BlazerLT's Avatar
AF -Advisor
Re: squeaky
Yea, I had to replace my swap bar end links and the sway bar bushings.
Did the ride ever tighten up after the install too.
I recommend the poly aftermarket end links and the rubber AC Delco sway bar bushing from the dealer.
