Old 02-07-2005, 08:12 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Talking 1996 Dodge Ram: 12" Lift, 4X4 Conversion, Super Swamper Tires....
Loosley based on the Dodge Ram VTS Pickup...
The front end was completly rebuilt. Parts used were: Completly rebuilt front frame rails using styrene block tubes, and made a custom IFS Crade using the same stuff. It has Nissan Terrano Lower A-Arms, Toyota Hilux Front Differential, Honda Civic SI Driveshafts, (they were actually bigger/longer),Toyota Hilux Spindles, with stock axles and upper control arms. I "lengthened" the spindles by adding bars at the top of them from the left over multi-link Teranno rear end. For the front axles, I cut the snap on wheel axle/hub from the stock parts, and instead of using the poly cup/thingy that you would normally used on an Aoshmia model, I glued the axle/hub in its place instead, so the wheels would still attach like normal. I also used Hilux front shocks. Has stock disk brakes and drums rear, custom stabalizer bar modified from a Rockwell 2.5 Ton axle, with a stabalizer shock, and a power steering unit from an International Paystar dump truck. The tires are Aoshimia Super Swamper Radial TSLs, with Raguna D-Force wheels...
The rear end has "enlarged" stock Hilux shocks (two shocks put together to make 1 long one), an aluminum differential cover, and I flipped around the leaf spring mount points, and lifted them using the block tubing.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 02-07-2005, 08:17 PM
blubaja's Avatar
blubaja blubaja is offline
Re: 1996 Dodge Ram: 12" Lift, 4X4 Conversion, Super Swamper Tires....
Hey,
Looks like you rolled uir truck there....but that's not what you were goin for...lol...good luck with your new body.
Frank X.
Old 02-07-2005, 08:29 PM
Oh yeah, to anyone who read my classified adds, I wont need a new body, I decided to order a new body from Revell. Except it will take 15-20 buisness days to arrive. SHIT!
LESSON LEARNED: NEVER LEAVE MODELS TOO CLOSE TO HEAT LAMPS! (THIS IS THE SECOND MODEL I ACCIDENTLY MELTED)
Old 02-08-2005, 04:31 AM
Jurva's Avatar
Jurva Jurva is offline
Looks interesting project. I have same kind of project in plannig. 99 Silverado 4wd conversion using Mad Mudder drivetrain.
Completed:
Top Secret Supra
Old 02-08-2005, 05:06 AM
Wheelin75r's Avatar
Wheelin75r Wheelin75r is offline
Wow, that's impressive!
Old 02-08-2005, 05:09 AM
Hyperkinetic's Avatar
Hyperkinetic Hyperkinetic is offline
A Dodge Ram, one of my favorites.
Looks like your roof now has a 'double-bubble' roof, just like the Dodge Viper it's based on
Good luck with your new body. I like the idea, a raised VTS. that's pretty cool
On the workbench:
Gunze Jaguar XK-E / Tamiya Peugeot 405 Pikes Peak / Fujimi Ferrari 365 GTB
Hyperkinetic Rabbity Thing!!!
Old 02-08-2005, 09:20 AM
ol' dude's Avatar
ol' dude ol' dude is offline
Looking to be a cool project!! GIT-R-DONE!!! Keep us posted on the progress!!!!!!
BUILD TO SATISFY YOURSELF AND NO ONE ELSE!
Click to view ACME's website
Old 02-08-2005, 11:03 AM
11chevy's Avatar
11chevy 11chevy is offline
Send a message via MSN to 11chevy
oh s**t!!!it is exactly that i wanted to do,
but anyways,i can't wait to see it done,
keep up the good work!
in progress:
Old 02-08-2005, 06:43 PM
After I Get my new pieces, I'm gonna either do it up blue with white Bumble Bee Stripes, or I might repaint it Hemi Orange with black Bumble Bee Stripes. Although Go Green with Black stripes would look nice too...
Opinions?
Old 02-08-2005, 07:34 PM
Jeep_Rubicon's Avatar
Jeep_Rubicon Jeep_Rubicon is offline
Nice Truck
Old 02-08-2005, 09:32 PM
SkylineMan32
Guest
Posts: n/a
Are ya gonna use the V10? I like it, yeah it did look like a roll over, you could dirty it up, and make it look like it had been rolled. That just my 2 cents
Old 02-09-2005, 10:35 AM
11chevy's Avatar
Re: Re: 1996 Dodge Ram: 12
Opinions?
i think Hemi Orange with black stripes could be good,
in progress:
Old 02-10-2005, 06:55 PM
More pics:
You can see i melted the door aslo. I tried to heat the roof back up with a lighter so i could straighten it out, but the flame bounced off the roof, and hit the door. I didnt realize it untill it was too late.
Sneak peek at the engine...
NewProcess205 Transfer case, modified Hilux front drive shaft, modified stock drive shaft with Aoshimia U-Joints (for better detail), modified exhaust that barley fits between the tranny support rail, and t-case
HURST shifter, gauges with gauge cover, (paint looks wavy/wet cause I just painted it)
Old 02-10-2005, 07:01 PM
SkylineMan32
Guest
Posts: n/a
I like it. That is a hell of a kitbash! Are spare parts from Revel cheap? I need a body, and windows
Old 02-10-2005, 07:24 PM
blubaja's Avatar
Hey,
You gonna put a skid plate under the transfer case? Lookin good so far. Keep it up..and higher..hehe
Frank X.
