Old 02-07-2005, 07:39 PM
turbo ES turbo ES is offline
got an idea
if i figured out a way to fit a superchareger on my stealth NA dohc would a eaton M90 work off a thuderbird or would it boost too much for my 10:1 pistons or will like 5 or 6 psi work with upgraded fuel system and exhaust. Also how much do you think it would add horsepowerwise. i also have a automatic transmission would it handle the extra power with a tranny cooler? i have read the faq thing but everyone says you have to put lower compression pistons in but they cost too much is it possible to boost safley with a stock engine?
Old 02-07-2005, 08:35 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: got an idea
No, not safely..that's why you're supposed to lower the compression before you boost, because it's not safe otherwise....i'm sure it'll work for a week or so though. If I were in your situation and could do it, i'd try it...I don't think 5 psi would blow anything up...but im not gonna say it's safe to do.
Old 02-07-2005, 11:38 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: got an idea
So wrong. Plenty of people run 10psi on 10:1 3s's. A few run 13psi with minor alky injection. Its all about tuning and fuel. 5-6 psi would be a cake walk withstock tt 360 injectors
Old 02-08-2005, 12:03 AM
uncutnick3kgt uncutnick3kgt is offline
Send a message via AIM to uncutnick3kgt
TO SAFELY boost a NA motor u should use tt compresion pistons and a better fuel system!
Old 02-08-2005, 08:48 AM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Re: got an idea
All i knwo is boost on stock engine is a no no...
we put a Supercharger on a ls1 transam pushing 10psi and a week later BOOM!
we threw a rod...
so think twice before doing it...
It might work but then theres a great chance it wont...
Upgrades... To many to list...
Old 02-08-2005, 08:59 AM
Stealthee's Avatar
Re: got an idea
Its done SAFELY on 10:1 ALL the time. Go look at the FWD Forced Induction section on 3si. And about boosting a LS1 most supercharger kits for it are designed to coincide with the higher compression. Either someone put on a much too small pulley or something else happened to cause it to throw a rod.
Old 02-08-2005, 12:00 PM
Igovert500's Avatar
blue + red light magnet
Re: got an idea
I think the disagreement here is due to knowledge of tuning...yes you can run 10psi daily if you know how to monitor and tune your car safely...for a beginer, you really don't want to push past 5-6psi. Lower compression pistons would help raise the margin of error.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-08-2005, 12:07 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: got an idea
You mean lower.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 02-08-2005, 12:23 PM
Igovert500's Avatar
Re: got an idea
Yeah, however the saying goes...I meant that lower compression pistons give you a larger 'safety threshold' and don't put you so close to the brink of potential disaster (if not tuned properly)
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-08-2005, 01:17 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
Re: got an idea
is there no need to lower the compression on the ls1 and lt1 with a supercharger?
Old 02-08-2005, 04:17 PM
Re: got an idea
so what you guys think it would do horsepower wise
Old 02-08-2005, 04:30 PM
Stealthee's Avatar
Re: Re: got an idea
If youd manage to make it work then you would look at about 280 hp at the crank with 6 psi.
old and good, the supercharger kits made for those applications are designed to work with the higher compression.
And for those of talking about wanting to change the pistons to lower the compression on your 3s so you could run higher boost, you would be much much further ahead just to drop a TT motor in. Buying the pistons plus tearing down your motor to install them would end up costing you as much as or more than just purchasing a used short block and swapping it.
